BC785D on SIM SERAM
plaws
E Hawkesbury Twp, ON
If you mean this system...
https://www.radioreference.com/apps/db/?sid=8086
the answer is no. This is a true P25 system, and I don't believe a scanner that old would work on a 700 Mhz system (which one site uses) in any case. Mike
I don't remember the limits, either, but even if all the channels were above 850 MHz, the real problem is that the 785 (and the 250) wouldn't follow a 9600-baud control channel. That pretty quickly lead Uniden to release the BC796D and BC296D which were otherwise identical but would do 9600 baud.
