BC796D Trunking?
carsonbm
Reminderville, Ohio
I just purchased this scanner and for the life of me I cannot figure out how to program for trucking. I need all the help I can get. Please try and keep it simple, I don't know the terminoligy yet.
Thanks :evil:
DJ88
Brick Twp., New Jersey
You would need to let us know what type or types of trunked systems you are trying to program. There are different ways to program different systems. If you had the name of the system, that would also be a big help. We may be able to go to the database here and find the information pertaining to the system.
Mike-KC8OWL
Henderson, NV
Are you trying to program everything through the front panel or are you using the software to program it. The software is the easier way to go if you are entering a number of talk groups and alpha tags.
Even through the software that Uniden packages is a bit weak, it is still easier than trying to program through the front.
I'm not sure which system you are trying to program, but both the Akron systems are Motorola Smartnet systems and should work just fine on your 796D.
Be sure to set the bank as a trunked bank or it will not follow trunked conversations.
Mike-KC8OWL
Henderson, NV
Can you hear any of the control channels? Even if you enter each of the freq.'s and hit scan in conventional mode, it will eventually stop when it hears the data on the control channel. If you can do that much, at least you know you can hear the system.
I'm only framiliar with the software that Uniden packages with the scanners so I can't offer too much help with the application you are using.
Night_Moves
Oakville, Ontario
Trunking
I,ve followed the trunking instructions a few time now and nothing, it scans but I hear nothing. the frequencies I put in are 141.4200 and 142.6650.
What am I missing?
Night Moves..... :?:
Dubbin
Findlay Ohio
Re: Trunking
What am I missing?
What you are missing is that that is not a trunking system.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Re: Trunking
Night_Moves said:
I've followed the trunking instructions a few times now ...but I hear nothing. The frequencies I put in are 141.4200 and 142.6650.
What am I missing?
By the looks of it, you are trying to monitor the Mississauga Site(9)
for the Ontario Bell Fleetnet System.
Have you followed the Sticky instructions on the top of the Canadian
Forum ?
Here, look at this link and follow the programming guide our moderator
has prepared.
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&t=8179
You should be good to go now.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
carsonbm said:
Summit county, Ohio trunk system
Forget about trunking for a moment. Do you hear anything , like
voice or data when you enter the freq's ?
If you hear the control channel you should be all set to try Trunk programming.
Why not put them in the old way by hand, but make sure you are entering in Motorola trunking mode.
It's only seven frequencies and shouldn't take long to set up.
http://www.radioreference.com/modules.php?name=TRSDB&sid=2707
Night_Moves
Oakville, Ontario
Help
I've installed the cd that comes with the bd796 and I'm still having problems :oops:
anyone willing to coach me over the phone in the Toronto , Oakville area would greatly be appreciated. :idea:
I'm not usually this stuped when it comes to electronics. :shock:
Night Moves..... :D
