BCD436HP/BCD536HP: BCD 536
joekehoe
Plymouth,Ma
I have programmed Plymouth PD, Kingston PD and Marshfield PD all in Massachusetts in the scanner. When it is in scanning mode the PD’s don’t stop for transmissions . However when in manual mode, they come in without any problems. Any thoughts about the digital channels when scanning.
garys
Central Texas
Check your squelch settings as well. When I had a 536, I found that anything more than a 2-3 worked as an attenuator.
dmfalk
Eureka
If they're on a trunked system, check to make sure you're not avoiding all sites. Another thing to check are each agencies' P25 NAC settings... They may not necessarily be using a NAC of 270, so you might want to set NAC to "search".... Worked for me here in Northwestern California...
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
I wouldn't suspect service types due to the fact that law dispatch is enabled by default (unless OP intentionally turned it off). Law tac is not enabled by default and should be turned on to monitor the frequencies tagged as such
@joekehoe, zip up your Sentinel .hpe export and post it as an attachment so we can have a look at your programming. Directions here
Looking at the RRDB, they're conventional P25
garys
Central Texas
Correct. UHF or UHF-T. Those are all in pretty close to proximity to each other, so he should be able to hear them.
Jokehoe might get better information in the MA forum area. There are several people on this forum who live in that area.
dave3825
Suffolk County NY
Plymouth digital freq looks like it’s simulcast and that scanner may have issues. How do you have them programmed in, conventional or P25 one freq?
