I am new in scanning. I am trying to program my new BCD325P2. I programmed my system via ProScan (tried FreeScan as well). Since FleetNet is the largest system in the world I program my location only for now (The Pas Site Details (MTS FleetNet)). The location has 1 control and one alternative channel, I deleted the rest of the channels. Set it to the Motorolla system (it is P25 SmartZone). I set the scanner into ID Search mode. In my understanding (pls correct me if I am wrong here) the scanner should understand that both frequencies are trunk control channels and start listening control channels only. In my understanding from reading this forum, when someone tries to initiate a transmission, channel freq. is being allocated and communicated via the control channel. The scanner should read the freq. and listen to it. Since it is one control freq. only, I should hear ALL talks in all talk groups.
Here is what happening: : the signal strength indicator flashes, on line 3 I have alternative trunk control freq (855.1125) most of the time, with main control freq (854.8625) appearing for a quick moment. I hear some communications (some times just ending of what seems to be a lengthy exchange), and it appears to be ambulance only. I cannot get highway, police, fire, however, judging from the RR db they all should be on the same network.
Should I add talk groups IDs and how can I see if the scanner works in control channel mode only?
