BCD325P2 Mass State Police help
garys
Central Texas
I used VUP to update the firmware in my 325P2. I don't think Sentinel supports it, at least I couldn't find any reference to it anywhere. The 325P2 doesn't have any HP like features to the best of my knowledge.
I also don't recall any rebanding on the MSP trunk, but it's been literally a couple of decades so my memory may not be clear. I've never tried to manually program a trunk system on any of my scanners since the 780 first came out.
Back to the OP's question. IIRC Zone 5 is rebanded, so you need a rebanded table if you're entering it manually.
The 325P2 is a Sentinel supported scanner. Just download the latest DB into Sentinel and load it into the scanner.
You can edit the favorites to delete what you don't want.
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
opny4c-5mHveLux8vnxk01ZnjEjHjjVGow28up83GWrBLwZHKvA4_cb8uREh8PxX7aH2NWdK5FGb6DDiF5Jf0HLOD8IFs-wAP9p08TMrM65xUPo5Zl41cvTMRhZ9lPGlaqY
tvengr
Well Known Member
Baltimore County, MD
You need to use the BC_VUP_3 updater and an internet connection to update the firmware in the BCD325P2. Save the attached zipped file to your computer and extract.
  • BC_VUP_V3_03_00.zip
garys
Central Texas
I've owned just about every Uniden program that Butel made, plus ARC500. I mean everything from ARC780 up through ARCXT. I switched to ProScan since it does everything all of those programs do and more.
Sentinel doesn't cover the 325P2, only the database scanners (SDS/X36HP/HP)..My advice is pay for software like ProScan or Butel ARC XT, it makes programming ridiculously easier
