BCD369T
Johnbk
West Valley City, Utah
I need some help.
Late December 2024 my Uniden scanner BCD396T no longer stops on programmed channels (SL CO UCAN) in manual or scan mode.
It's as if there was nothing there.
I didn't do anything to the scanner. No channels are locked out. The speaker works and my squelch is at 2.
Could there be something wrong with the scanner?
I am stumped ..
hazrat8990
Wyoming
If you are trying to monitor the Motorola system, it was totally abandoned. Everything is on the new P25 phase 2 system now, so you have a bit of programming to do.
Edit: Actually, you will need to upgrade your scanner to one that is capable of even receiving P25 phase 2.
gldavis
KE7MQF
Bountiful, UT
I have currently logged 548 separate Talk Groups on this system alone, within range of my antennas. Of these, 11 have encryption. That means there are 537 separate unencrypted Channels, in use.
