bcd396 scanner
N0WEF
Mpls, MN.
If I understand your question, you can do it in the free 396t software, or through Freescan.
Like you want it to say your name when you turn it on right?
In the free Uniden software - It's under Miscellaneous, then look for "Opening Screen"
N0WEF
Mpls, MN.
What software do you use? (It'll save me a lot of typing.)
N0WEF
Mpls, MN.
Ummmm..... To do what you want to do, you will have to download software that programs your scanner.
2 free options are, Freescan, or the easier to use uniden software BCD396t_USAD from thier site
After DL'ing one of those, it will be easy. Thought, be sure you download the programming in your radio to the software so you don't lose it.
N0WEF
Mpls, MN.
You might be able to, but even if you can, it would take forever.
KB1ZDG
i have a 396xt
*You can't change the opening screen through the scanner itself*
You have to use software to change the opening screen. I recommend using Free Scan to do so. It works well with my 396XT.
Jacob
N0WEF
Mpls, MN.
Oh, If you have the XT you will need FreeScan. Once you get the software, and cable, set up. Shoot me another PM and I'll walk you though it. (Sorry, I missed your 6:22am post saying xt)
N0WEF
Mpls, MN.
Cool, it's under the "scanner" (at the top of the window) then click "Set up scanner options" then its under the "general" tab.
You'll see it on the right side of window.
Sorry I missed your post yesterday morning, the site was having issues with posts.
KB1ZDG
ok am back is it called startup message?
Yes it is. I think you can enter 4 lines of text there. There is an option to center the text also to the left, center, or right side of the display.
Jacob
dispatcher812
Connecticut
Is there a way for this to be done on a 796D? I have the Bearcat programming software but could not fin anything about the message. Will a FreeScan software for my scanner do it?
Never mind, just found the wiki, it will not work with the 796D.
