BCD396T and BCD996T Updates are Here
hiegtx
Dallas, TX
ka3jjz said:
OK I must be missing something. Maybe a bad download?
Anyway, I've already downloaded and applied the ESN update. I have also gotten the BC_VUP_v.2.0.0.3 and BCD396T_v2_00_07 zip files. I've unzipped them and executed both. I got an Uniden folder set up under Program Files, but nothing in the BC_VUP folder.
What am I missing here?
73 and thanx Mike
Mike,
Did you merely unzip the BC_VUP file, or let it extract & do the install routine?
If you did the install routine, but the folder is empty, then either your download was defective in some way, or the installer sidetracked itelf somehow.
In the BC_VUP folder (a sub-folder under Uniden, under Program files) there should be at least two items: BC_VUP.exe & BC_VUP.ini
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Nope I did the full install, not just unzip - I guess I'll have to wait until I get to work to re-download the VUP file. Darn 73 Mike
hiegtx
Dallas, TX
Want me to:
a. Email you the file
or
b. email you (zipped or not zipped) the two files that should have been in the BC_VUP folder?
The BC_VUP.exe & BC_VUP.ini files may also be on your pc, just in the wrong place. Tried a search yet, to see if they are there? then drag them over to where they belong?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Thanx no, I can wait. There's nothing critical that I can't live without for a few days. If I download again, and I still get nothing, I'll post again.
73 Mike
Help UPMan - Registration Key Not Working
I have a 996 that I bought a couple of months ago. I went to update the programming today and the registration code I was given by Uniden says there is an error with the code. I cannot program my scanner, as it will only run in demo mode.
I tried reinstalling the program and reinstalling/running the firmware update and still have the problem.
HELP??
UPMan
In Memoriam
Arlington, TX
This thread is about firmware updates. The registration key for the software (UASD) is not the same thing as the registration key for the firmware update. If this is about UASD, better to start a new thread (but I'll tell you now that the answer is to just go to the web site and request a key...). If this is about firmware updates, you need to register your scanner, including ESN and ESN checksum, then request a key on your "All My Scanners" page for the v2.x update.
bdp278
New Orleans, La
Installed ECN update & now scanner is dead
Last nite I was in the process of installing the ESN firmware update onto my BCD396T. In the middle of the update, my computer locked up, I had to shut down, and now my laptop gets a blue error screen when I turn on.
Anyway, the real question is now I have attempted to re-install the ESN update from another computer this morning, and it shows as the update completed, & shows me a screen w/ ESN number 32826164058770 & checksum # 191. When I attempt to enter this info into the My scanners page to update the info, I get another page stating the 2 number do not match. Now I cannot power on my 396T to try to reterive these numbers directly from the scanner. However, the scanner will power up in transfer mode when I press L/O & 6 & insert AC power plug & I get the lighted blue blank screen, but cannot power up in a normal mode either w/ batteries and/or AC adapter.
UPMan
In Memoriam
Arlington, TX
I just checked and verified that the ESN/checksum pair you show above are valid. So, I suspect you typo'd when you entered the info into your account.
educastillo
bcd 396t
tengo un scaner bcd 396 me sigue perfectamente los canales digitales de motorola pero no he podido determinar cuales son los canales de control de edaccs alguien me puede ayudar.
loumaag
Silent Key - Aug 2014
Katy, TX
Translated said:
I have a scanner bcd 396 perfectly follows the digital channels to me of motorola but I have not been able to determine as they are the channels of control of edaccs somebody can help me.
EDACS channels must be placed in the correct logical channel order (LCN). The control channel is not important, all channels must be placed in the system for it to work.
Los canales de EDACS se deben poner en la orden correcta del canal lógico (LCN). El canal de control no es importante, todos los canales se debe colocar en el sistema para que trabaje.
educastillo
Canales Edaccs
GRACIAS A LA PERSONA QUE ME LO TRADUJO......TENGO UNA DUDA CUALES SON LOS CANALES (LCN) AL SCANEAR LAS FRECUENCIAS HE ENCONTRADO UNOS QUE ME SALEN (CTL1)-(CTL2)....(CTL5) SON LOS MISMOS? ADEMAS ENCUENTRO HASTA DOS CANALES (CTL2)(CTL3) SEGUN ME HAN COMENTADO AQUI HAY VARIOS SISTEMAS EDACCS QUE PASA SI REVUELVO LOS DE UN SISTEMA CON LOS DE EL OTRO SISTEMA COMO LOS IDENTIFICO.GRACIAS POR AYUDARME
D
DaveNF2G
Guest
CTL significa que él es canales de control. El número para cada uno indica su número de canal lógico (LCN).
educastillo
En Un Mensaje Anterior Me Dicen Que Los Canales Control No Son Importantes Pero Entiendo Que Ctl Es Igual A Lcn Debo Incluir O No Los Canales Control?
educastillo
Como Diferencio Los Canales Lcn De Un Sistema A Los De Otro Sistema Dela Misma Area..en El Area Donde Vivo (bogota -colombia ) Hay Dos Sistemas Uno De La Secretaria De Salud Y Otro Del Acueducto Y Me Aparecen Repetidos Los Canales Ctl
educastillo
Ademas De Los Canales Lcn El Sistema Edaccs Necesita Algun Ajuste Mas Como Base De Frecuencia O Algo Mas ? O Solocon El Ajuste De Los Canales Lcn Me Arranca? Debo Ajustar Algo Mas? Tengo Un Scanner Pro 95 De Radio Shack
D
DaveNF2G
Guest
Para eschuchar EDACS, usted debe incorporar todas las frecuencias del sistema en orden del LCN, incluyendo los canales de control.
educastillo
Orden Logico Lcn Para Escuchar Edaccs
Para Escuchar Edaccs Debo Incluir Todos Absolutamente Todos Los Canales De Voz Incluyendo Los De Control?
Orden Logico(lcn) Significa En Forma Asendente Ejemplo 855.300
855.800
856.100
857.200
857.600
Los Canales( Ctl) Debo Incluirlos En El Mismo Orden Logico
D
DaveNF2G
Guest
LCN es a menudo igual que orden numérica ascendente, pero ése no es siempre verdad.
Hi, I am trying to update my 396.. I have downloaded the ESN_Loader application, and followed every step precisely, but everytime I go to update it, my computer shuts down..
This happens everytime and its very annoying, any help?
Thanks alot
