loumaag
Silent Key - Aug 2014
This subject comes up quite often so an explanation of what this message means, when it appears, and how to avoid it seems appropriate. This thread is not for comments, merely for reference.
"Nothing To Scan" will appear on this scanner under various situations, each of these has a different solution so I will address all that I am aware of and how to avoid or fix the problem in each case.
1. Nothing in the scanner - If the scanner has nothing programmed in it, of course it has nothing to scan, so this is most obvious reason. The solution is to program some systems and scan away.
2. Everything is locked out - This happens if everything in the enabled systems are actually locked out. Note there is a difference between locked out and disabled. Locked out happens if you program something as Locked or press the <L/O> key. Disabled happens if you press a Quick Key (System or Group) and toggle the system or group off. The solution in this instance is to unlock something in the system so that the scanner has something to do.
3. All Systems are disabled - This happens if you toggle all currently programmed systems to Off. Since you have turned everything off, the scanner has nothing to do; the solution is to enable a system and the scanner will happily carry on scanning.
4. All Groups are disabled - This is different than above and seems to cause the most problems with people understanding what has happened. The best way to understand this is a hypothetical situation. Say you are scanning a single conventional system programmed to one SQK (System Quick Key), let's use SQK #3 for example. All other SQK's are disabled and this system has 3 groups of frequencies on GQK's 1, 2, & 3. If you disable all three GQK's the radio will then properly state it has "Nothing To Scan" because you have turned everything off. The problem that seems to confound everyone at this point is that in addition to the "Nothing To Scan" begin displayed, the GQK disabled icons " * " are no longer displayed either. In other words although the System shows to be active (the #3 is showing along with "S0:"), there are no groups displayed. The solution is quite easy, press and hold the <Function> key, turn the scroll knob and find the system covered by SQK #3, the GQK icons will be present and while still holding the <Function> key press 1, 2, or 3 and the scanner will be able to scan again.
You can avoid this "disappearing icons" situation in two ways:
If I have missed a way this can happen or if something needs to be corrected, please PM me with your comments.2. Everything is locked out - This happens if everything in the enabled systems are actually locked out. Note there is a difference between locked out and disabled. Locked out happens if you program something as Locked or press the <L/O> key. Disabled happens if you press a Quick Key (System or Group) and toggle the system or group off. The solution in this instance is to unlock something in the system so that the scanner has something to do.
A. Don't ever disable all GQK's in a conventional system.
B. Program at least one frequency in the "default" group (one not assigned a GQK #) and do not lock it out. It can be a frequency you want to monitor for this system or it can be a frequency that is unlikely to have anything on it (like 1300 MHz).
Note: This problem does not happen on Trunking systems because the scanner will always scan the frequencies programmed even if you disable (or indeed lock out) all of the Talk Groups.B. Program at least one frequency in the "default" group (one not assigned a GQK #) and do not lock it out. It can be a frequency you want to monitor for this system or it can be a frequency that is unlikely to have anything on it (like 1300 MHz).
