bcd396xt finding control channel
shifty277
So what would cause my scanner to randomly say this for state police frequencies? It was working fine till all transmissions stopped and now it says finding control channel.
Thanks!
UPMan
In Memoriam
Arlington, TX
It is unable to find a control channel on any frequency programmed for that system. This could be because the control channel changed to one you've not programmed or the control channel is not receivable (like being out of range).
fxdscon
¯\_(ツ)_/¯
But I programmed the entire state with freescan.
Check the RR database and see what has changed for the area that you monitor.... something has changed as far as control channels.
shifty277
So then how do you add more control frequencies? Is that under the site then trunk frequencies?
shifty277
I cannot find the control channel for my area either by listening for the buzzing noise..
shifty277
So I found the control frequencies. I added all of them and it still says Finding Control Channel...
Any ideas?
WA0CBW
Shawnee Kansas (Kansas City)
Either you don't have the correct control channel frequency or you are out of range of the control channel. This is assuming the scanner hears other transmissions and is working correctly.
