BCD396XT/BCD996XT: BCD396XT won't connect to FreeScan
MURSman
Bump. Should I just get another cable, or try out some other troubleshooting methods?
tvengr
Well Known Member
Baltimore County, MD
Here are the instructions for installing the driver.
If you are having problems installing the drivers, see the following general instructions (some steps might differ slightly, depending on your specific operating system).
  1. Download and unzip the above driver.
  2. Plug in the scanner using a USB cable.
  3. Right click on the Windows Launch icon (bottom left corner) and select "Device Manager."
  4. The device shows up with a yellow triangle.
  5. Right click on device and select "Update Driver Software."
  6. Select "Browse My Computer for Driver Software."
  7. Navigate to the folder where you have unzipped the above driver.
The driver installed and is assigned as: Uniden Serial Port (COMx)
(x) will be replaced with the actual port number.
Brales60
Punta Gorda, Fl
Thanks, doing some chores. I give it a shot later. We have company coming over in about an hour.
Brales60
Punta Gorda, Fl
No yellow triangle.
