BCD436HP/BCD536HP: BCD436 Speaker Replacement
MarkinTO
Toronto, ON
Recently, my friends speaker in his 436 blew. He constantly had it set too loud at fire scenes. Being here in Toronto, Canada I reached out to Uniden for a replacement. They no longer have parts and apparently don't support this model anymore. So, I searched. There was 1 place in the states that had the part but they won't ship outside of the "continental states". So, I found some originals in England. Pricey though! But... I had a thought... I had a dead Baofeng UV-5R that was dissembled for parts. What are the odds...? Turns out that it has the same size 2" (32mm) speaker and the impedance is only off by 8ohms. Original is 24ohms/.5watt, the Baofeng is 16ohms/1watt. So, this could be an alternative fix? One must be handy though, to remove the part from the dead speaker in the 436 and steal the connection part with the "tangs" that connect it to the circuit board and mount it on the Boafeng speaker. Or, one could simply use some extremely small gauge wire and simply solder them to the pcb of the 436. So, if you can't find an original replacement, this is a good "work around". Wish you all well. Oh... on the subject of low audio output (limited by Uniden) from the headphone jack... I'm told that connecting a tiny wire from the antenna ground to the output ground of that jack, will bypass the 24ohm resistor (installed to protect our hearing), thus giving much more output. Keep in mind that a "Stereo" plug MUST be used when connecting external devices to the 436 Output jack, otherwise you're shorting out 1/2 of it's output and pressing the audio-amps output circuits.
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
It's relatively easy to replace yourself if you're able to get a spare speaker. The speaker blew out on my 436, and I had a spare 436 that had been damaged but the speaker still worked, so I swapped the speaker, good as new.
Maybe there's an aftermarket place to get the speaker?
MarkinTO
Toronto, ON
MarkinTO
Toronto, ON
Yes, it's a very simple repair... Assuming... one can get the speaker itself.
hexagon_keyhole
Sacramento, California
Might just have to plug it into an external speaker if you can’t find a replacement speaker on the cheap, and Uniden Flat Rate Repair isn’t an option.
MarkinTO
Toronto, ON
That's what my friend has been doing. Plugging it into his vehicles sound system and/or using an amplified speaker in the meantime.
hexagon_keyhole
OK, I have personally never ordered from this company before, but it appears that they have the speaker available? Not sure if Canada shipping would kill it? Uniden reuses certain parts across different product lines, but on the looks of it this might be your best bet?
MarkinTO
Toronto, ON
Thanks. That would have been useful info several weeks ago. No blame on your part. Uniden, or at least the person I'd contacted told me they were available at all any more. Even the place I did find them at, refused to ship to Canada. Thanks though...
Noseybody
Eastern Ontario Canada
Bluetooth transmitter plugged into earphone jack and a Bluetooth Anker speaker. Sounds great.
Isn't there is a Canadian Uniden repair center no? Peterborough?
