BCD436BCD comments
KSDeputy
Lecompton, KS
I bought a BCD436HP scanner. My computer died, so the scanner has been sitting her for weeks. I now have a new computer. I tried to read the included manual, printed in Vietnam, and it is way beyond my comprehension. Scannermaster tried to sell me an easier to read and understand manual for $ 30. I declined as I thought they were trying to take advantage of me.. Does anyone know about this improved manual, and if it is worth $ 30? Part of the problem is that in the years I have listened to the radio systems I like on my BCD250 portable, the scanner business has changed so dramatically that it is far more complicated than the front button programming I am used to. Once re-banding occurred my scanner would no longer pick up the agencies I listened to. That is when I awakened and bought the new digital scanner. Is there a much simpler to read and understand manual for people like me? Is it available free?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Where is the Siren app?????????
In development with Uniden, slated for a first quarter (aka Q1, aka by March 31) release.
However, as this is a thread about the 436, the app is for the 536 and its wifi connection, so the 436 will not make use of it.
ajcscan
West Salem, Ohio
So I ordered the 436 scanner from scanner master and I am wondering if they will update the firmware when they program it for me? Any thoughts?
Sent from my Note 2 on Tapatalk
Dafe1er
Off in a far away place, far from u.......
Some places do update the firmware and test units out BEFORE shipping and some do not.
It is not to hard to update these scanners. Everything is done in the Sentinel software.
phask
zanesville
IMHO - if you need to have it programmed and / or have someone else update the firmware, the scanner is probably beyond your skill set.
You're going to have someone do this for you, then next week have a whole litany of questions on why , how, what's this for.
I just don't get it.
greggk
York,PA
This new 436 has seen many of us, even the experts, asking why, how, or what does this do. Thats why we are here...either to answer or to learn.
I agree, however, that the owner/user should be able to figure out the zip code. I believe that everyone should be able to dive in and get their hands dirty experimenting with the radio; you won't do any permanent harm.
And I said this before and got jumped on, I am not entirely comfortable with paying a lot of money to have your zip code put in for you before it is shipped. I doubt that anything else is actually done....IMHO.
Greg
ajcscan
West Salem, Ohio
I am not against learning everything I can about this scanner. I just wanted it to be instantly ready out of the box for me? I am currently without a computer so, programming it myself is out of the question via Sentinal. I do a lot of traveling so I will have no option but to program it myself depending on were I go. I am also a licensed HAM operator and have been now for almost 20 years and I'm no stranger to programming radios. My biggest issue right now is time. I did not mean to offend anyone, I simply wondered if ScannerMaster will update the firmware? I would hope so, but no big deal if not! Once I get my new computer, I can do it myself.
Here's another question for you.....Is it necessary to install Sentinal from the scanner first or can you just download it from this site?
Dafe1er
You are going to need to update the firmware and database once you receive your new scanner. Sentinel is a program you have to download to a PC and use to program/ update your scanner. You can program the scanner by hand but it will take a little time as you have to use a series of button pushes and knob turning to get it done.
Personally, I use the software as I find it a pain with these new scanners to do it by hand. You said you do not have a PC right now and you travel. Why not find a local Pawn Shop in an area you will be around and see if you can find a cheap laptop to use. Should be able to find a good deal there or on Craigslist. It will make your life a lot easier.
Just use the Zip code feature for now.
You should be able to get by to listen to wherever you are for most things.
Most of the stuff updated will be re-naming some. New Stuff added will properly mean more to a Local the to I'm Visiting here for a short Time.
If you ask them to update the Firmware because your not having access to a Computer for a while, hopefully they can do that for you as a courtesy, If not find an other Dealer.
In this age of Time some of us can and will be more Flexible then others.
Good Luck and have Fun once you get it.
N7CAS
Reno, Nevada, USA
BCD436HP: Batteries Only?
Am I correct in concluding that the BCD436HP can only operate on batteries? It recharges the batteries via the USB cable obviously, fine, but that's it. The manual is horrible.
N7CAS
Reno, Nevada, USA
Also, of course I realize that Radio Reference's database has its faults but it is (at least in my area) a very solid starting point. But does the database download completely? I wonder because I have yet to hear some highly active frequencies that I have seen included in the Web site database (even labeled correctly). Is there a way to specifically check what is downloaded? Example: it's odd to only hear one single channel in my city's police department when it uses several, and all of them noted online in the Web site database.
davenlr
North Little Rock, Ar
Incorrect. When you plug in the USB cable, and it asks "Serial or Mass Storage" if you hit the "." button to put it in serial mode, it will be running on the USB power, not the batteries. In this mode, it will not charge the batteries while the scanner is turned on. It will ask you if you want to charge them when you turn the scanner off.
greggk
York,PA
You may want to consider a battery charger. There is a HUGE discussion of the battery charger here. http://forums.radioreference.com/uniden-tavern/285105-uniden-batteries.html
Also, some good stuff here: http://forums.radioreference.com/un...234411-uniden-home-patrol-nimh-batteries.html
HAPPY READING !!
Greg
phask
zanesville
Sure - download Sentinel, update to the latest database and look at it. You can see everything that is in it - no scanner needed. Anything not in it can be added in a favorite.
jpolich7
Opaque Instructions, Bizarre Software, Faulty Controls
Youall may be interested in my post today to the Uniden Owners Tech Support sub forum titled "Opaque Instructions, Bizarre Software, Faulty Controls." I probably should have posted it here instead.
davenlr
Check your settings under SERVICE TYPES on your scanner if you have a 436/536. Its possible the service types for the channels you are wanting to listen to from the database are turned off in the scanner. For example, if you have three busy police channels, and one is dispatch and one is tactical and one is talk around, if you are only getting dispatch, then the service type for Law-Tac and Law-Talk might be turned off in the scanner.
Another possibility is that they are encoding those other channels, and the scanner will not receive encoded channels.
N7CAS
Reno, Nevada, USA
After extensive familiarization with my new radios making sure setups are correct, the BCD436HD and BCD536HD (at least the two that were shipped to me) are definitely buggy and I am not happy about it.
THE 436:
On the first charge of the 436's supplied brand-new batteries (14 hours) via a USB port, "Normal Charging" was properly diplayed and switched to "Charge Complete" after 14 hours. I then used the scanner on battery power, testing its service time. Much to my dispappointment, scanning only one system (in battery save mode) the batteries only lasted 3 hours before the 436 generated a "Low Battery" warning. This is not good. In comparison, my BCD396T lasts for days with casual use.
In any case, concerned and curious, I re-charged the batteries. I expected a 14-hour cycle as before with their initial charge. As of this morning, the 436 has been showing "Normal Charging" for 30 hours straight. No "Charge Complete."
I nor anyone else have any use for a portable scanner whose batteries discharge so fast and then, insult to injury, don't re-charge on the second attempt where upon the first they did. And unlike my 396, there is no option (at least yet anyway) to work around the battery stuff by powering it with anything but a USB.
THE 536:
The 536 randomly mislabels some transmissions. I've monitored my local systems for quite some time — I know who's who (for example, I can tell the Green channel dispatcher apart from the fire department's Red channel — and I shouldn't be sporadically and suddenly hearing fantastically different communication contents on a completely unrelated Talk Group ID. I double-checked the database; the TGIDs are correct there. Also, those TGIDs are not linked. This, while occasional, is still annoying.
The display information is thus unreliable. When a small town out in the middle of nowhere, 233 miles away, comes up on the display and it's my region's metro tactical communications, something's not right.
Worse in the unreliability area is the tendency for departments with previously active comms not but 30 minutes prior just dropping off, gone. One example: High-traffic, 24-7 paramedic dispatch and support channels. Poof. Gone until one turns off the radio and then turns it back on.
I had, up until now, complete faith in Uniden products. I have used them for nearly 40 years since the company's initial incarnation as Electra Bearcat (1975's BC-101) along with other manufactures, and for reliability in my view Uniden's line has only ever been rivaled by one single other particular model (Radio Shacks's old PRO-2006).
That said, I realize there are bound to be glitches with these two new products, the 436 and 536, and hopefully they will be quickly addressed in future downloads of the firmware/software.
There my good faith ends. If these issues are not resolved in future downloads of firmware/software, though, and this uncharacteristic mediocrity is what one can expect from Uniden these days for this kind of money, I'll be shipping the 436 and 536 back as the defective items they currently are and demanding a refund under warranty.
AK9R
Staff member
Super Moderator
Central Indiana
If you have legitimate and reproducible bugs to report, they should go here.
