BCD436HP in Niagara Region need help
Iceman74
Just got my scanner. Programmed it according to radio reference, have all OPP, EMS, St Catharines, Niagara Falls fire but I'm not picking up welland ..port colborne. Fort Erie fire.
Is it because I'm too far away? What would be the reason?
Thanks for any advice
Iceman74
When you hold on a control channel, do you have any signal level? If not, yup too far.
I dont think I have any signal even when it picks up opp EMS niagara falls fire an st Catherine's fire .OS there something I need to adjust
BC_Scan
Vancouver BC
I use one of these on my car and one of these in my house:
https://www.talleycom.com/viewProduct?rlProdNum=MXRBMAXSCAN1000
https://forums.radioreference.com/s...on-tri-band-vs-scan-force-mobile-antenna.html
re the Larsen,
I find generally that the stock antenna is not sufficient, so always use one of these two and dramatic increase it makes, you dont say anything about antenna , so im going to assume this is your first and now you need to pony up, than you should be able to hear signals from afar.
Remember height can be your friend , so get antenna up as high as cable will allow for.
Also try search mode , ie scan the range of the control channels of a trunk you want to hear and if the scanner stops on the active one , you are generally in range if not, too far, Good luck
Iceman74
Didn't ask about antenna because I'm still trying to figure this unit out.
Thank you, I will try that.
Iceman74
Why am I not getting Welland, Fort Erie, Port Colborne and Wainfleet fire?
I live in Niagara Falls and get them and St Catharines.
Any suggestions? Are they all digital or some analog?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Iceman74, please keep your questions in one thread. This way you can find your answers, if people respond, in one place.
Iceman74
You are monitoring VHF signals. You need to get yourself a decent VHF antenna.
So you think that's what the problem could be the stock antenna..
What antenna do you recommend see if it fixes my problem
Iceman74
The only 2 I get are Niagara Falls and St. Catharines, gonna try changing the antenna maybe it will help.
