In the middle of this I started thinking about how redundant the trunktracker V is redundant as it is flexible.
Since some of the nationwide or statewide systems are in several counties/states, why not just make a favorite list that you can toggle on and off each one like CB/GMRS/FRS, trunking system A, trunking system B, trunking system C. If you had state A and state B most likely many of the records were going to repeat being scanned if they are all favorite list enabled at the same time. Idea being saving time and energy going back through the full database for items you already have in another favorite list duplicated and make another favorite list for overlapping entries in multiple counties. Sure the TTV works fine in the field without the use of sentinel, as organizing the favorite lists by trunking system or common system like CB would require sentinel.
Now if you use the gps option, it'll do that automatically. But still don't always need the rarely used frequencies which can be turned off/on in the select service types.
