BCD436HP/BCD536HP: BCD436HP Possible Issue
xxjunior78xx
Elmsdale, Nova Scotia
Hello,
So I'm new to the scanner scene. So I bought a BCD436HP because I did some research that this is a good starter radio, because programming "can be a nightmare to newbies". So what my issue is with the digital frequencies. The scanner picks them up, stops, but nothing is being broadcasted. Other channel frequencies work fine. Ive tried some youtube videos but hard to figure out this one. Read the manual also and couldnt find anything. So is there a setting I need to change or enable? any help ladies and gents would be greatly appreciacted. Also I live in Canada, so not sure if the digtal frequencies are different from area to area.
dave3825
Suffolk County NY
Digital is digital. How are you trying to listen? Using zip code and full database or did you create a favorites list? And also, the 435/536 sometimes suffer from simulcast depending on certain factors. Some people say that scanner wont work on simulcast at all, but there are many others how listen to simulcast systems without issue. If you could post a link to the system your having trouble with it would be helpful.
xxjunior78xx
Digital is digital. How are you trying to listen? Using zip code and full database or did you create a favorites list? And also, the 435/536 sometimes suffer from simulcast . If you could post a link to the system your having trouble with it would be helpful.
Hey Dave, I'm using the zip code and full database. I didnt create a fav list. I have the talkgroups on I want to hear in the settings. I just purchased the DMR upgrade. So I'm waiting now to see if that fixes the issue. I was unaware you needed that upgrade to hear some of the frequencies.
dave3825
Suffolk County NY
You only need Dmr, Nxdn or Provoice upgrades if the freqs you wish to listen to are those. Is what your trying to listen to DMR? P25, will work right out of the box without any upgrades.
xxjunior78xx
I’m pretty sure they are DMR. I know it does say in the bottom corner they are P25. But for police and EHS it won’t play audio. Just stop on the frequency. It will do Fire P25 and other P25. How do I know if it’s DMR frequency from the list for Nova Scotia Canada for Halifax? I appreciate the help to the newbie too!
xxjunior78xx
That was the first thing I thought of. Are the frequencies you're trying to listen to encrypted? As mentioned, post a link to the RRDB page for the system in question.
How do I know if they are encrypted on my scanner? Also what’s RRDB page? I’m a newbie and learning. Thanks for the help.
xxjunior78xx
Also purchasing the DMR didn’t help getting the voice to broadcast.
drdispatch
If 1000 hertz, think what 1 gig must feel like
Fightin' River, Michigan
We were all new at one time.... 😁
Radio Reference Database. There is a page for each state and province. Nova Scotia is here:
Find the system/agency you are trying to monitor. For each frequency (or talkgroup if it is a trunked system), check the "Mode" column. If there is an "E" in that column, it is full-time encrypted, an "e" is part-time encryption. No scanner will decode encryption.
RMason
Mississippi / Colorado
I believe that this is the system you are trying to monitor. It is a P25 - Phase I system. To see what is encrypted, look for DE in the Mode column. The “E” indicates that the TalkGroup is encrypted.
xxjunior78xx
So it says they are DE or D. More DE. So that means no matter what I can’t listen to those channels?
fxdscon
¯\_(ツ)_/¯
Correct. The capital "E" means full time encryption which can not be monitored by any scanner.
xxjunior78xx
That’s correct. That’s the system I’m trying to monitor. But I guess where it is encrypted my BCD436HP won’t monitor all the channels is what I was told. It will some, but not all.
xxjunior78xx
What I find shocking is how much digital encrypted we have in Nova Scotia. All our local police, ambulances and RCMP are. Not like it’s a high crime rate or anything here…..lol
mass-man
trying to retire...
Parker Co., TX
I just looked thru the system and indeed that's a lot of E. As happens here in the US, fire stuff is usually not encrypted. Ambulances encrypt for "patient confidentiality" or at least that's their excuse. Police depts and statewide cops for officer safety! Or in other words, because they can. Dig around through the archives and you'll find long discussions about encryption. For many of us it's meant moving into other areas to listen to...aviation, railroads, etc.
