BCD436HP screen DUST!!!
Hit_Factor
Saint Joseph, MI
I just read this thread; it seems that this is certainly a warranty issue and should be repaired by Uniden.
I wonder if Toyota will wash my car for me? It's been through a tough winter, I don't know how I could be responsible, I keep in in a garage, except when I'm driving it.
I know, not very helpful. But suggesting dirt from use is a warranty issue, just seems wrong.
pinballwiz86
Missouri
Did you miss this photograph? Dirt from use? It's on the inside of the display.. You can't be serious.
Hooligan
Clark County, Nevada
If you washed your new car with the windows up but water was getting into the passenger compartment during the process, I suspect you'd be whining to Toyota instead of making some defective analogy.
greggk
York,PA
If you put out $20,000 for a new roof, and the first rain had water coming thru your living room ceiling...is that a warranty issue ?
My point was that no one who spends $500.00 for a scanner, then gets such bad dust under the screen in a few months, should have to live with this or, even worse, clean it themselves.
I would be just as angry if it were me. I looked at my new 436, and even with a screen protector on it I did not cover that area on top as shown in the pictures. I have mine in a case as well. Tomorrow its black electrical tape, in small amounts, around that seal and then back into the case for me.
Greg
kmurphy41
Los Angeles, CA
I'm going to taking mine apart 2 get rid of the dust. is it tricky ?
Sent from my HTC6435LVW using Tapatalk 4
al95
Brownsville,Texas
Rain water was entering my brother 2009 Ford F150. The rain was coming in thru the Top Stop light also known as the third stop light. I took it in to the dealership they had to replace the gasket that surrounds the top light trim(lens). It was covered under the factory warranty. I wonder if this is covered Uniden Factory warranty.
greggk
York,PA
My guess is that Uniden will not cover your Ford F 150 warranty. :)
(Sorry..I could not resist.)
no8rf
Port Huron, Michigan
I just read this thread; it seems that this is certainly a warranty issue and should be repaired by Uniden. I put a screen saver on mine, but I also left those small rounded corners open. Since I am using a Scannermaster case, I will probably put black electrical tape on those vulnerable areas and then back in the case again.
JAKE---Call Uniden and see if they can help.
Greg
Can anyone who opened the case post a few pictures of it here?
I E-mailed Uniden and they stated it was not that big of a problem and if there was a large dust build up to send it back in and they would take care of it. Did not like that answer why not make it right to begin with.
W2SJW
Senior Member
Northwest NJ
As I've stated earlier - take off the antenna & remove the batteries. Take out the 6 screws in the back of the unit & the front cover will lift right off if gently pulled straight away from the front of the unit.
I took the earphone plug off my beat-up Pro-97 discriminator rig, and it fits perfectly. It seems to have stopped this issue.
nr2d
Laurel Springs, NJ
You can probably just blow it out with your breath. I have a $6000 piece of Ham Radio gear that gets dust on the inside of the display cover all the time. It's annoying but I just bend over an blow lightly and the dust just goes away.
drake2b
OMAHA,NE.
436 Screen Dust
I also am getting some screen dust. Used some canned air and that works fine!
I have a old IC - R-2 the earplug off of it fits the 436 just perfect.
W2SJW makes it sound as if that is where most of the dust comes in!
Will give it a try.
Have a couple of Pics attached I hope..
no8rf
Ear Plug Cap
So again if this is the cause for the dust getting in why does Uniden not offer this as standard equipment, I for one have never purchased a hand held that didn't have a plug for the mike and earplug, but if you don't let Uniden know they won't care, in fact I told Bearcat warehouse about the problem and they said they have never heard anything about that problem and as stated before Uniden didn't really care.
LIScanner101
Palm City FL
Strangely my PRO-18 doesn't get any dust under the screen, and I have pretty good eyes so it would be hard for me to miss it. It also has a dust plug for the headphone jack on top by 99 times out of 100 I leave it unplugged so I'm sure dust is getting in there.
greggk
York,PA
Jake..how long have you had the 436? I thought you only had the home patrol as posted on your "shack" photos.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Jake, what exactly is your picture supposed to show?
This is a thread discussing dust getting in behind the screen and your picture doesn't seem to show any?
Let's keep in mind the original purpose of the thread and not get sidetracked.
greggk
York,PA
Jake, I could not see anything either. However, what I was going to suggest, and apparently my last post got lost in cyberspace, is that if you do not use your headphones, then place a small piece of black electrical tape over it. I did with mine and along with a case you cannot see it. Also consider a screensaver that overlaps the seam.
Greg
