To make an IP address trusted in Windows 11, you can follow these steps based on your specific needs:
1. Add an IP Address to Trusted Sites (for Internet Explorer/Edge settings)
This is useful for allowing specific IPs in browser-related security settings.
- Open Control Panel and go to Internet Options.
- Navigate to the Security tab and select Trusted Sites.
- Click on the Sites button.
- Add the IP address (e.g., http://192.168.x.x) to the list of trusted sites.
- Uncheck "Require server verification (https
for all sites in this zone" if necessary.
- Click Add, then Close, and finally OK to save changes15.
2. Whitelist an IP Address in Windows Firewall
This is useful for allowing specific IPs through the firewall.
- Open the Start Menu, search for Windows Defender Firewall with Advanced Security, and open it.
- Click on Inbound Rules on the left-hand side.
- On the right-hand side, click New Rule.
- Select Custom Rule and click Next until you reach the "Which remote IP addresses does this rule apply to?" section.
- Choose These IP addresses, then click Add and enter the desired IP address.
- Complete the wizard by selecting Allow the connection, naming the rule, and clicking Finish34.
3. Add an IP Address to Trusted Zones via Registry
For advanced users, you can manually add an IP address to trusted zones using the Windows Registry.
- Open Registry Editor (regedit).
- Navigate to:
text
HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMapKey
- Create a new key under ZoneMapKey (e.g., Range1).
- Add the following values:
- :Range (REG_SZ): Set to your IP address (e.g., 192.168.x.x).
- file (REG_DWORD): Set to 2 (indicating a trusted zone).
- Repeat for other users under HKEY_CURRENT_USER if needed15.
4. Use Group Policy (GPO) for Multiple Users
For managing trusted sites across multiple users or systems:
- Open Group Policy Management Editor.
- Navigate to:
text
User Configuration > Policies > Administrative Templates > Windows Components > Internet Explorer > Internet Control Panel > Security Page
- Enable and configure "Site to Zone Assignment List."
- Specify your IP address and assign it a value of 2 (Trusted Sites zone)5.
By following these steps, you can ensure that a specific IP address is treated as trusted in Windows 11, whether for browser settings, firewall rules, or system-wide configurations.
