BCD325P2/BCD996P2: Questions on what to do when I first get my BCD325P2?
RandyKuff
Lorain, Ohio
Looks like the decision was made Wednesday to sell it. Don't know why everyone is wasting their time with this?
His classified add is kind of bogus...
He says unopened box and that it has the DMR and NXDN upgrades...
Thats not what he says in post #35...
werinshades
Chicago , IL
Yes, I noticed this too but wasn't going to go down that path. As been said here many times, "buyer beware".
hiegtx
Dallas, TX
I’m not going to speculate as to whether the poster was trying to muddy the waters on whether it was a truly “new” scanner, box unopened. However, if the poster purchased the scanner from a dealer such as ScannerMaster or Police Scanner Outlet (aka Bearcat Warehouse), the purchase may have included adding the upgrades by the dealer before shipping to the original purchaser. Adding upgrades requires physical access to the scanner both for determining the electronic serial number via the scanner menu as well as keying in the upgrade key.
After “installing the upgrades”, the seller would have then repositioned any items removed from the box, as well as the now “Optimized” scanner, then resealed the original box. As far as the original purchaser is concerned, the scanner was still ‘new in box’, hence that may be why it was posted for sale as being ‘unopened box’, since he had not opened what appeared, to him, the original OEM packaging.
RandyKuff
Lorain, Ohio
Says he bought it from Uniden...
To much conflicting verbage between post #35 and the classified...
AngWay
Curious
Buchanan, Va
I understand that, and you've done everything you can for this guy. He's going to sell it because he doesn't understand everything some have sent to him to read. I'm not sure if more is going on with him based on some of his postings, but the scanner world/trunking/P25/DMR/NXDN is over his head. You tried...
basically u don't know what u are talking about . it has dmr and nxdn it will trunk track no i'm though about selling it ... but your ur information it is now deocoding analog just fine so i mus know something about what i'm doing, with the help of others of course. so if u have nothing informative to say don't say anything besides bash my questions. have a nice day . oh btw did u ever figure out the OFT problem by yourslef>?
AngWay
Curious
Buchanan, Va
u are totally wrong i bought it from uniden i got the receipt to prove it. not everyone is a lier
AngWay
Curious
Buchanan, Va
I run a fleet of SDS200's SDS100's 536's 436's 996p2's 325p2's BCD160 and BCD260 all but the x60's do P25 Phase 1 and 2
with no issues.
Your best bet is to.
1. Start over and not import from any scanner.
2. Use you PROSCAN and build your Scanner File for your 325p2.
3. Are both Scanners using the same type antenna?
i did try starting over and programming it fresh with proscan . imade sure to use the 325p2 version of proscan to both scaners are connected the same antenna i said that once already
AngWay
Curious
Buchanan, Va
I have looked over the post and you never answered our question.
Did you upgrade the firmware in the 325p2?
Just changing the 536 file name and changing the Scanner type to 325p2 and programming is not the way to do this.
yes i upgraded the firware the day i first got it i reinstalled proscan for the 325p2 as well.
AngWay
Curious
Buchanan, Va
decisions can change. but if i can't ask for help on here regardless what i decide to do with my property then neither should u
AngWay
Curious
Buchanan, Va
yes first was gonna go with amazon made the order then read that they could be refurbished so i cancelled my amazon order and went with uniden .. not hard to figure out if one knows that facts
AngWay
Curious
Buchanan, Va
a guess a person can't decide to buy the dmr and nxdn at a later time it must be bought when the scanner is new i guess.
RMason
Mississippi / Colorado
here is ur zip from the 325 from proscan
I have reviewed your 325p2 proscan file. Here are some suggestions:
  • Put various 325p2 settings back to the default
    • Turn battery save off - I have seen reports that this setting can result in erratic behavior.
    • Turn P25 low pass filter off
    • Turn off priority scan
Your programming contains 31 systems with 35 sites and 248 channels. While I don't see anything obvious, going through the file can be compared to looking for a missing comma in War and Peace. From your comments, it is not clear to me that the hpe files represent what is actually programmed in the 536. I simply don't have confidence that the 325p2 and 536hp you are comparing to have the same programming. There are too many variables to track.
It sounds like you have started to start over and program by importing systems from RR rather than using your 536hp programming. I think this is your best approach. Your 536 sentinel hpe files are not the best place to start. Start small and take it one step at a time. Program one system at a time. Identify what frequencies seem to be working and what traffic is missed. I suggest focusing on systems that are nearby before trying to tackle distant systems. Solve one problem before moving on.
i even started over and reimported every thing i listen to from radio reference into proscan for the 325 i used utilites to make sure everything was tuned right. it made things worse instead of teh 325 just scanning it would start making screaming and roughing noise . i deliberlty and made sure not to add dmr or nxdn until i seen that this scanner would at least decode analog like my 536 and sds100 would
Again - do you have the dmr and nxdn upgrades installed? This sounds like you are either receiving a digital signal on a channel programed as analog - for possibly an encrypted signal.
when i bought this 425 i thouht well at least one thing it will do better than the dma type scanners is decode analog better boy i was wrong
Focus on getting the 'easy stuff' working first - then move on to the more distant systems.
werinshades
Chicago , IL
i deliberlty and made sure not to add dmr or nxdn until i seen that this scanner would at least decode analog like my 536 and sds100 would . i don't want to pay $110 for upgrades when the scanner itself won't even decode simple analog like my 536 a
i was gonna add the dmr and nxdn but did not so if anyone wnats to buy a BCD325P2 brand new
:unsure:...buyer beware.
EAFrizzle
Bond. Ward Bond
SE de DFW
Dang.
As much as I've griped about my SDSs, and how much I enjoy my 325P2, ain't no way I'm making the trade he wants.
AngWay
Curious
Buchanan, Va
BUDDY U NEED TO JUST STOP OK JUST BECAUSE WHENI GOT THE SCANNER I WANTED TO TRY AND SEE HOW THE ANALOG DID WITH THE 536 ON JUST ANALOG ALONE. BUT SINCE THEN THE 325 HAS STATED DOING GOOD SO I BOUGHT THE UPGRADES LIKE I SAID I PROB WOULD IN MY POST....YA KNOW ITS PPL LIKE U THAT RUIN THESE FORUMS U ASSUME CRAP AND TELLL OTHER PPL LIES WHICH IS WHY I JUST HAD A LONG CONVERSATION WITH @blantonl U MAY KNOW HIM REAL NAME STEVE. BUT YEAH STOP SPREADING LIES WHEN U DON'T KNOW WHAT THE FACTS ARE . OK LIKE ME AND STEVE DISCUSSED IT'S GOTTEN TO WHERE U CAN'T ASK A QUESTION ON RR ANYMORE WITHOUT PPL JUMPIN IN AND RIDICULING U WHEN UR JUST A BEGINER TRYING TO LEARN TRYING TO FIGURE THINGS OUT . I'M SURE U ASKED ALOT OF DUMB QUESTIONS AT ONE POINT . AND I HOPE PEOPLE TRIED TO HELP U INSTEAD OF SAYING LOOOK AT THS FOLKS HE SAID HE DOESN'T WANT TO UPGRADE HIS SCANNER ALMOST LIKE CIRCUMSTANCES CAN'T CHANGE . ANYWAY'S I READ UR POST ABOUT HOW U COULDN'T GET UR DMR OFT TO WORK OR HOW TO DO IT WAY BACK WHEN AND I WAS GLAD TO SEE PPL HELPING U AND NOT TELLING U GO READ A BOOK ORSOMETHING CRAZY. ANYWAY'S I RANT BECAUSE WHAT U SAID AND QUOTED TO REALLY PISSED ME OFF TO SAY THE LEAST U DON'T KNOW MY LIFE OR WHAT I BUY DONT' BUY SELL OR DON'T SELL. SO KEEP UR NOSE OUT OF MY BUISNESS OK IF I ASK PPL FOR HELP AND MAKE A POST JUST PASS ME BY I'M ALREADY SEEN THERES THOSE OUT THERE THAT WANT TO HELP INSTEAD OF DIG UP BULL CRAP TO 'WARN PEOPLE" BUYER BEWARE LMAO HOW ABOUT RR USERS BEWARE OF YOUR UNEDUCATED ANSWERS TO THERE QUESTIONS. GOODNIGHT ! I HOPE U GET THAT DMR OFT FIGURED OUT. DUH OH AND STOP STALKING MY POSTS IT SURE SEEMS THAT WAY . I RECALL SAYING THE SAME THING ABOUT THE SDS100 I BOUGHT AND NOT GETTING THE UPGRADES BUT THEN DID , BUT I SOLD THE SDS100 GLAD U WASN'T STALKING MY REALLY OLD POST IN ORDER TO RUIN MY SALE
AngWay
Curious
Buchanan, Va
U TAKE THAT OUT OF CONTEXT TO
I SAID THAT WEN I FIRST GOT IT .
I SAID THIS WHEN I COULD NOT GET THE SCANNER TO DECODE ANALOG . NOW IT DOES. SO LIKE I SAID U HAVE TAKEN THINGS OUR OF CONTEXT AND THERE TIMELINE THEY WERE SAID AND U ARE GIVING PPL ADVICE AND BEWARES WHEN U DON'T KNOW WHAT IS CURRENTLY GOIN ON ..IT'S LIKE ME SAYING DONT' TALKE TO @werinshades BECAUSE A YEAR AGO HE SAID HE HATED SCANNERS IN GENERAL , AND QUOTED WHERE U SAID THAT , BUT TODAY A YEAR LATER AFTER U LEARNED ABOUT SCANNERS AND BECAME VERY SMART ON THEM THEN IT WOULD HAVE BEEN WRONG FOR ME TO TELL PPL TO NEVER TALK TO U AGAIN . RIGHT . SAME CONCEPT HERE UR TAKING THINGS OUT OF CONTEXT AND ADVISING PPL ON WHAT TO DO NOW THAT IS A CRIME THAT A PERSON SHOULD BE PUT ON MODERATION.. BUT THATS NOT HOW THAT WORKS IS IT @BLANTONI
