BCD536 HP- Issues Resolved?
TonyN2KI
Washingtonville, NY
As a prospective buyer, has Uniden fixed the dimming display issues, RTC issues and also what is the scanner enthusiasts opinion that the 536 series is close to End of Life? Thanks for your thoughts.
hiegtx
Mentor
Dallas, TX
The RTC and dimming issues were fixed quite some time ago. Uniden set up the repair program for scanners exhibiting the problem, and also made changes to the new units being produced to also include the replacement parts used in the repair campaign. I have had zero issues with my 536 & 436 that went in for that repair in the fall of last year. Also not seeing any reports of 'repaired' scanners come up with the same issue again.
Only Uniden knows if the 436/536 are near end of life. But a comment made by UPMan a month or two ago indicated that they were definitely not being discontinued any time soon.
jonwienke
More Info Coming Soon!
VA
The problems were fixed in new production units about 18 months ago.
And there is no indication of a replacement model any time soon.
buddrousa
You loose the backlight or the display? If it is the backlight it is covered. If it is the display connect to it remotely and look at the contrast settings. Or option 3 get it repaired.
lou9155
shamong nj
had the unit for 3 months, on powering down the display pixelated and disappered...no graphics at all.. i have backlight and was able to upload to sentinel ..all my settings were as they should be..called uniden and they said to send it in its under product warr.
jonwienke
VA
That is not a common problem, and uniden is fixing it under warranty.
N9RMA
Tony While you are waiting for delivery; down load the software, config to what you want and your go to go. Had my 536 repaired under the repair campaign and nodda problems since..73 from a fellow ham. Bob N9RMA
garys
Central Texas
I don't believe that Uniden has exhibited at CES for some years now. I think they host an invitation only "hospitality suite", but that's about it.
Anything expected at CES?
Sent from my SM-G900T using Tapatalk
CQ
Exosphere
Made a Good Choice
I got mine back on Monday from the RTC repair and they also did the display but never noticed any dimming since I always run my equipment at low display settings or off.
Here is the new color of the display but had to increase the brightness so it didn't look like a sort of sepia color.
Enjoy your new gear!
