BCD436HP/BCD536HP: BCD536HP Cannot Connect via USB
ckqualls
Dallas
I've been out of the hobby for years, so learning again. I connected my Windows 11 laptop to my BCD536HP via USB, and when I try to write to it (Scanner, Write) it comes up to microSD, no option for USB.
What am I doing wrong?
dave3825
Suffolk County NY
You should always read the scanner first, to preserve any avoids etc. Then add or modify, then write back. Are you selecting mass when prompted?
N9JIG
Sheriff
Moderator
Far NW Valley
Be sure the scanner is in Mass Storage Mode. When you plug in the USB cable it should come up on the radio screen, press the "E" to go to Mass Storage More. The SD Card should soon thereafter show up in Windows with a drive letter and also in the popup window when you select Write to Scanner.
ckqualls
Dallas
Did that, nothing comes up on the scanner screen nor computer (Sentinel) screen. Press the E button, nothing happens.
I don't think its a cable issue. I first tried plugging into the USB C port, then tried plugging into the USB A port with another cable. Tried both USB ports on the computer. I know both work because I use them for other applications.
I just noticed on the scanner's screen, right center, there is an icon with ! (exclamation point) next to it.
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
Is the scanner powered on when you connect the USB-mini to USB-A cable? You're plugging into the port encircled below? If you tried more than one USB-mini to A cable to no avail then you could be dealing with a faulty port
A Look at the Display
Appears to show Wi-Fi status is not connected (BCD536HP Only).1722109913444.png
N9JIG
Sheriff
Moderator
Far NW Valley
Yes, you need to use the USB-Mini port on the front of the scanner as shown in Whiskey3JMC's post above, the rear port is for the WiFi dongle only. (There is no USB-C port on the scanner.)
Alternately you can program the 536 via the SD Card with an SD Card reader, it will work the same way, just select it with the appropriate drive letter when writing to the scanner.
