BCD536HP Model number mismatch error
wyocommo
Have been attempting to upgrade the firmware in the unit unsuccessfully.
Unit currently has 1.10.02 FW.
Upgraded Sentinel to 1.07.5. Upgraded the database in the unit successfully. Attempted to upgrade firmware but get a 'Mismatch Model name' error before the upgrade starts and that is the end of the process.
Uninstalled Sentinel and re-installed but no joy.
The following appears in the detail drop down box:
************** Exception Text **************
System.ApplicationException: Mismatch Model name.
at HomePatrol_Sentinel.SntlFileHeader.ReadFile(String PathName)
at HomePatrol_Sentinel.TargetVersion.GetVersions()
at HomePatrol_Sentinel.HomePatrolInfoForm.HomePatrolInfoForm_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.8745 (WinRel.050727-8700)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
BCDx36HP_Sentinel
Assembly Version: 1.0.0.0
Win32 Version: 1.7.0.5
CodeBase: file:///C:/Program%20Files%20(x86)/Uniden/BCDx36HP%20Sentinel/BCDx36HP_Sentinel.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.8750 (QFE.050727-8700)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
UPMan
In Memoriam
Arlington, TX
That is a very odd error to get. What is the entire contents of the "Firmware " screen on the "See Scanner Info" menu?
wyocommo
Thanks for your reply.
I found the solution to the issue.
If the database is not turned on, you will get this error. I am unsure is the database turned itself off when I did the upgrade or ?. I don't remember turning it off for any particular reason.
