This may or may not be of use to some or any, but I'm hoping it will help. Just as important, I'm hoping somebody will take a look and help me out with making some improvement. It is probably only applicable to people living in larger metropolitan areas. I know its long and if you are not struggling with this issue there is probably no reason to run through it.
Slow Scan - Workaround
My Situation - I live in the Portland, OR metro area and - for any locals - I have omitted discussion of Vancouver/Clark Co. for simplification. Basically, I have three separate counties to scan police and fire. There is more, but I want these set up and working. All three of these counties are served by two trunking systems - Portland Public Safety (PPS) and WCCCA. Each county is primarily served by one trunking system, but makes limited use of the other for some TGID's. All counties also have at least one conventional system in addition to these for some frequencies.
I have always had 6 banks (one police and 1 fire/ems for each county) containing the relevant control channels and TGID's. I wanted my FL's to match this configuration for convenience and control. Using Sentinel, this is what it looked like.
F0-Washington Co - Police
---S0 WCCCA
------Police Departments 0 thru nn
---S1 PPS
---S2 Conventional Sys
------Departments 0 thru n
---S3 Conventional Sys
F1-Mulnomah Co. - Police
---S0 PPS
------Departments 0 thru nn
---S1 WCCCA
F2-Clackamas Co - Police
---S0 WCCCA
------Departments
---S1 PPS
------Departments....
.....and so on - giving me three police FL's and three fire/ems FL's.
What was happening (I think) - It is worth noting that the bulk of the TGID's are in S0 for each FL and the lesser used TGID's are located in the higher S numbers. Considering the scan order F0,S0; F1,S0; F2,S0;.....F0,S1; F1,S1; F2,S1....F0,S2; F1,S2; F2,S2.... - The first pass through the FL's yielded the best results, the subsequent passes yielded limited results because all the good stuff is in the S0's. I was just waiting for 2 or three passes through the FL's - often for nothing.
Also, I had assigned QK's to all of the sites that Sentinel brings in when you add a system or department into your FL, turning off all QK's except the simulcast site in each system within each FL. Even though the QK's were disabled, I could still see them flash by in the display.
All of this leads up to an initial performance that can only be described as abysmal.
The Experiment - Through a series of tweaks throughout the past week - the details of which I cannot fully recall, but did include "Avoid" all but the simulcast site within each system in lieu of shutting off QK's - I got this to where performance was just poor.
I set up 6 FL's for my 536HP that were nearly identical to 6 banks in my BC785D. The major difference for obvious reasons, is the site setup for the 536HP is as described as above and for the 785D - banks contain only control channels and is set for Ctrl Ch only scanning. Over this weekend I ran multiple 5 minute tests at various times throughout the day with both units going where I counted the number of transmissions captured that had an audible voice (not channels that were stopped on) - more on this later.
The results: My brand new 536HP received 85% as many transmissions as my ~6 year old 785D - of those it did land on my 785 beat it there 25% of the time. I have no data from the initial setup, but sadly this was a dramatic improvement.
The Improvement - For people that may only have this issue, this might be enough. In any regard, the following change is an improvement for me and may be good enough if I can solve another fundamental issue with this scanner - "Missed/Cutoff transmissions"
Very simply, I renumbered all of the systems to S0 to cut the number of passes through the FL's to once. From above:
---S0 WCCCA
---S0 PPS
---S0 Conventional Sys
---S0 PPS
---S0 WCCCA
.....and so on.
I believe (but can't really verify) the scan order is now; F0,S0; F0,S0; F0,S0....F1,S0; F1,S0; F1,S0.....F2,S0..... - "Systems with the same QK are scanned in order of creation" from pg 51 of my manual.
The Results: Now my new 536HP catches 90% of the transmissions as my old 785D and still gets beat 25% of the time.
Other Factors - I hadn't realized how big of an issue that I had with missing or incomplete transmissions until I started counting. I decided to do a modified experiment, albeit on a limited sample size relative to the first two. I decided to count any stop on a channel whether it had audible voice or not.
The Results: The 536 caught 94% as much as the 785D.
This is still not stellar, but would probably be getting much closer to even.
---S0 WCCCA
---S1 PPS
---S0 PPS
---S1 WCCCA
---S0 WCCCA
------Departments
---S1 PPS
---S0 WCCCA
---S0 PPS
---S0 PPS
---S0 WCCCA
.....and so on.
