Since you bought it used, I'd suggest looking at the serial number, to determine when your scanner was manufactured. Many of the early production scanners had problems with the battery that maintains the real time clock not doing its job. Uniden had a service program to address this on those units, as well as some display issues. But that campaign ended some time ago.
See this Wiki page:
Uniden Scanner Serial Numbers - The RadioReference Wiki
That will help you determine when your unit was built. If it was in 2014 or 2015, or the first months of 2016, it's possible that it was eligible for the repair, but the previous owner never sent it in. If you have the scanner connected to your PC, and are using ProScan, letting the software update the correct time & date would be the easiest path. Since you are also not getting the option, when booting up the scanner, to reset the time & date could indicate that that firmware update was skipped. Put the scanner in mass storage mode, and have Sentinel check to see whether a firmware update is in order.
As
Randy has already noted, time and date are used to account for when recordings are made. A wrong date or time has no effect on actually scanning systems for activity. But if letting ProScan maintain the time & date for you is not what you want, then your option would be to send the scanner in for repair.
