Ubbe
You could still have some USB problem, as Windows should automatically check the SD card for file integrity as soon as you connect the USB cable and announce that it has found errors and asks if you would like to fix them. For some reason that function have been disabled.
Write cache are by default disabled and you will have to set that policy manually to that SD card by right click on the drive and select to use write cache.
You could use another USB port on your computer to check if that works differently.
/Ubbe
/Ubbe
