Ok, I did notice the signal bar was good (2 to 4 bars) on the Sem Co system depending on the channel but the screen shot is of the local Orlando CC not the troublesome Sem Co system.
I do find it a bit strange the BCD996P2 works fine on the Orlando system and I have towers all around me.
It is currently hooked up to the Discone as I also use the scanner for other stuff like Air and ham bands. I was also able to get 100% copy on the scanner using the yagi but I had it mounted low (about 6 feet above ground) to attenuate the towers to the right, left and behind and pointed it at the closes tower.
In any case the little mini computer with the SDR and DSDplusFL is working great and it has Bluetooth so I have it paired to my Echo dot for the audio output. It's a really neat system that really did not cost all the much.
