BCD325P2/BCD996P2: BCD996P2 volume offset behavior
bw415
I have had my BCD996P2 for 9 years and just learned something new about it this week.
I have used the volume offset setting before but always to reduce the volume of certain channels that were too loud. Last week I set a positive volume offset for a new channel I added because it was a little lower in loudness than most of the others. This positive offset seems to override the main volume control as well. With the volume control turned all the way down (at 0) the channel with the positive offset can still be heard. It's at a low level but still can be heard across the room. Is this normal? I would think that with the volume knob turned down to zero no sound should be heard no matter of any offsets made to any channels.
Just wondering if anyone else experiences this? When I'm on the phone with an important call, I usually reach over and turn the volume all the way down on the scanner. Now I can still hear the channel with the volume boost.
bw415
Yes but the + setting will not increase the volume above 100%
Thanks. Not expecting volume above 100% but I was expecting a volume of 0% with volume knob down.
bw415
Well, +3 is greater than 0, so...
Yeah I get it, but it seems like it shouldn't override the master volume control at 0. No problem, I'll just turn it off instead of down. Thanks.
  • Like
Reactions: wtp
kc2asb
NYC Area
Sounds similar to the old Plectron alert receivers, which did not allow the volume to be turned all the way down. It was a safety feature so that calls would not be missed. Never tried this feature in my 996P2.
  • Like
Reactions: wtp
trentbob
Silent Key W3BUX
Bucks County, PA
Yes my experience with volume offset is.. if you have objects set to +2, +3.. you will not get that advantage of extra volume once volume dial is set to full volume, it hit the max on those objects 2 or 3 notches from maximum volume.
