BCD996T program digital only channel...
APX8000
Sarcastic Member
AES-256 secured
How do I program a channel for digital only ? A department I listen to uses both analog with a PL and digital on the same frequency and I want to hear the digital transmissions only.
Same for a trunked system. If I know the talkgroup is digital, can I set the software so it decodes faster?
kb9hgi
IL
UPMan said:
Set the channel to Digital Only (it is a channel option).
I can not find this option in the 996 where is it at?
campd715
Southeastern Connecticut
If you have access to the BCD996T owners manual look at page # 87 under 'Setting the audio type'. Hope this helps. This is a great radio but there is admittedly a learning curve compared to the older type radios. Good luck.
Dennis
