BCD396T/BC996T: BCD996T - Useless?
wyrmzr72
I've been handed a BCD996T, which had the original firmware. After some research, I've managed to get the firmware upgraded, but it seems that the system still isn't picking up the digital channels that my local PD has moved to.
It does find some kind of signal, but it's just static/white noise. I'm in Floyd County, IA, and it hasn't been that long ago they moved to digital. Does anyone have any tips/tricks for this particular scanner, or am I looking at a V1/V2 signal difference?
dave3825
Suffolk County NY
If your trying on the Iowa State Trunked system, the site in Floyd County is Simulcast. Not sure how that scanner will do with Simulcast. In any event, there is only mention of firmware being updated. How did you program the scanner and what software did you use? White noise/static could mean its not programmed correctly.
dave3825
Suffolk County NY
Actually, that scanner wont work on Iowa Statewide System as its P25 Phase 2 and that scanner does not seem to support that.
  • Like
Reactions: TGP
wyrmzr72
I programmed it with the Uniden Software, the BCD996T_UASD is what it seems to call itself. I used the online interface from that program. It is set APCO P25, Dynamic Scanning, I'm new to the digital side of things, but have the programming cable, obviously.
wyrmzr72
That would figure. The old analog channels still exist, but are not being used by the PD, of course. So they're out of luck just due to the age of the system.
dave3825
Suffolk County NY
wyrmzr72
OK, thank you for the info. Looks like they'll need an upgrade.
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
There are very few counties on Iowa's system that a 996T will work in, only those with FDMA talkgroups (mode "D") will work. Unfortunately the OP's county isn't one of them. Add simulcast distortion to the mix and that may bring the "working" county number down even further. I'll echo Dave's recommendation for an SDSx00.
Welcome to the forums, wyrmzr72
I wouldn't go as far as calling the 996T "useless", though there isn't much analog documented in your county I'm sure if you tune around the bands you may hear something of interest. Perhaps Aviation, Railroads?
  • Like
Reactions: wtp
StoliRaz
£uck Encryption
What might be useless to one man is still very useful to another. Still tons of analog and P25 phase 1 near me. I use my 996T almost daily. You could always sell it and put the funds towards a phase 2 capable scanner.
hiegtx
Dallas, TX
While, as already noted, you should look at an SDS100 (portable, hand held) or desk/mobile SDS300, which is how your 996t is categorized), you might look at downloading and installing FreeScan. While that is abandoned software, as noted in the Wili as well as referenced in multiple posts, It does have better support for your 996t than the UASD Software, and, if I recall correctly, can import program files created in the UASD software.
hiegtx
Dallas, TX
Keep it for airband scanning and buy the SDS100/200 for P25 desk/mobile scanner. Looking at my earlier reply, I see I typo
the model number of the desk/model. My typo was SDS300. Bearcatrp has the correct unit, which is the model SDS200.
wyrmzr72
Thanks, all. I've just informed the owner of this system that it won't do what they had hoped.
It's been a while since I did a deep dive into the world of scanners; that was back when you could get signals that you weren't "supposed" to. Like, cordless phones, your neighbor's hearing aids, transmissions from the Commie Martians down the street...
My last scanner was an analog handheld cheap Chinese variant. I made it easy on myself by getting the programming cable, as I can do almost anything with a PC (been building/repairing them for 30 years).
chris451rr
iowa
In Linn they have SARA phase1/2 that patches ISICS P2 systems down to P1 and there are a lot of P1 radios on it so 396t works fine there, Floyd county looks too far away to pick up linn, maybe with antennas you can tap into Dubuque. Simulcast is hard to decode outside of its 'zone'...unless you use horizontal beams. Time for a P2 scanner. Or unitrunker if you tap the discriminator. The traffic on ISICS is about 20% encrypted.
