BCT15X or 996XT Lower Volume Wx Alert?
Eng74
Kern County, CA
The weather alerts on all scanners are at a set level so someone will not have it turned down and miss something that could save a life.
Just curious if a 15x or 996XT has a way to lower the volume of the weather alert. It is SOOOO loud. Too loud!
You can work around this issue by using the tone out feature of the radio. Obtain the local frequency for the NOAA WX Station and input it in a tone out slot, set the tone out frequency A only to 1050.0 Hz and when the WX alert tone is broadcast while the scanner is on the frequency it will open up the squelch.
This stops the SAME weather alert advantage but you can set the volume to whatever you wish and use the tone out delay to close the squelch after a period of time. You can set the alert tone sound and volume to whatever you wish or turn them off.
Hopefully this will not wake up the better half when there is a amber alert @ 2 am. ;-)
SLJ2137694
Lehighton, PA
When I am sleeping and the scanner is 2 ft away from me I don't need it screaming full blast to awaken me. It isn't a Uniden or goverment responsability to assure that we can hear the alarm, if it was then the weather alert function would always be on. It is the responsability of the user to assure the volume is appropriately set for the situation. I have chosen NOT to use the function just because is it can't be adjusted to an appropriate volume. I am sure many others have taken this stand also! So Uniden, what good is the weather alert function if people choose not to use it? As I understand it, and I may be in error, our scanners ARE NOT required to have the volume of the alert at full blast. I have been told this is a manufacturers decision. Uniden, give us the option, and there-by we accept the responsability, of lowering the volume!!! If I have been informed wrong please let me know, Thank You.
Eng74
Kern County, CA
It is not just Uniden but the GRE's are the same. I have known people when the quick call goes off that it will still not wake them up and it turns the lights on too. I know of a couple times when my bed had to be kicked. Remember when you are useing it as a weather alert radio, it is not a scanner then, it could fall under different rules then. Where is one of the guys up on all the FCC stuff, maybe UPMan could give a reply with all the why'sand for's.
FlashP
To market the scanner as an alerting device, they have to comply with the CEA specifications for both RF decoding and aural alerting.
safetyobc
South Arkansas
Does that mean they cannot have a user selectable volume? Maybe just have it default to the loudest, but make a selectable volume available. That would be nice!
But for now, I'll use the Tone Out feature as mentioned above.
W6KRU
Vista, CA
I have read a lot of complaints about the volume of the weather alert and I was curious how bad it was but I had never heard one. This week we have had some unusually bad weather and it provided a good opportunity to hear one. I had 2 alerts yesterday and I think you guys are whiners. :lol::lol:
KE4ZNR
Radio Geek
UPMan has said this in the past:
We adhere to CEA-2009-A specifications which call for a minimum 77dB at one meter within the range of 500 to 1500 Hz.
We consider All Hazards Alert to be as critical as your smoke detector in its ability to rouse you from near death to take action.
So don't expect variable volume anytime soon :)
Marshall KE4ZNR
gary123
It is loud infact its almost 95 DB at 3 feet (measured with a chaep radioshack sound meter) being loud enough to wake you is fine but being so loud you are deafened and cant hear the alert is another :) .
perhaps uniden would concider a hidden menu adjustment for this feature along with a warning along the lines of "adjusting the alert from the preset value will void the CEA compliance and/or warrenty for that unit" Uniden can cover thier "butt" by adding a digital marker in the unit memory showing that the level had been adjusted thus releasing them from any action.
There is a way to change the WX alert in the firmware, but you need to figure out how to download it, change it and upload it back to the radio.
KE4ZNR
Radio Geek
Yeah, good luck with that.
Any change in the firmware would at the very least void the warranty.
Not to mention you would need to decompile the firmware, find out exactly which bits to modify, and write it back to the radio without bricking the radio.
Basically, not gonna happen.
Marshall KE4ZNR
rvictor
Milwaukee, WI
I assume that all of you that want it less loud would be willing to indemnify Uniden as to any lawsuits and resulting judgments that it might sustain as a result of making it less loud, right?
When there is a safety standard and a company fails to comply with the standard, liability often follows. Uniden appears to be smart enough to not do that.
Dick
SLJ2137694
Lehighton, PA
Dick
Of course I would and I am sure others would also. For me it would make the alert functional as I refuse to have it 2 feet from my ears while I sleep and have it go off full blast!!! Uniden could clearly make it mentioned in the on-screen set-up function (do I have the correct terminology here?) and in the manual/CD that modifying the volume would release Uniden from any responsability. How good is this function if people refuse to use it? It is only a good marketing tool. I am reaching back in my memory now and I don't have the time to read alot of postings from the past, but didn't someone mention that Uniden wasn't required to make the alert that loud but decided to do it anyway? If they were not required by law to do so they would be serving their customer base very well by addressing this concern so we/I could make use of this feature.
gary123
I certainly would have no issues protecting uniden against action. The only way I can see for uniden to proactivly protect itsself would be to do as I suggested, make the level adjustable but also set the software to "mark" a memory location so that it can be shown that the level was adjusted from the factory level (no mark= un modified). We use this method in our software it lets the end user make changes they want but releases us from liability (the mark is write only and cannot be changed back).
KE4ZNR you are right although it would be nice to be able to edit the firmware , there are lots of changes I would like to make.
rvictor
Milwaukee, WI
You obviously don't understand the concept of indemnification or you lack good judgment. From what you say you'd be willing to agree to pay all legal fees and judgments that Uniden might incur as a result of making the change that you propose. Unless you have no assets, that would be a pretty foolish thing to do and, if you have no assets, your indemnification wouldn't be worth the paper it was written on and Uniden would be foolish to rely on it.
Dick
K9JDN
Madison County, Illinois (STL Metro-area)
I like this workaround idea of using the Tone-Out function of the scanner for a WX alert! It's too bad the Tone-Out function of the scanner couldn't be expanded to "decode" the digital FIPS codes when an alert is sent via the NOAA frequency. That would be a neat "function" of the scanner, without jeopardizing Uniden's compliance with the CEA specifications of the WX_Alert function.
rvictor
Milwaukee, WI
It is not a sure thing that the method you use does, in fact, release you from liability. Even if it were to be ultimately decided that it did, you could spend thousands of dollars litigating the issue. Of course, if you have liability insurance, then your insurance company could spend the thousands of dollars.
With respect to the merits of indemnification, see my prior post. Frankly, I'm amazed that my rhetorical question was really seriously considered as a possible solution that at least two of you would consider doing. Just goes to show how foolish things get here and how little people understand the workings of our legal system.
How's this scenario? A family of four is wiped out while they are sleeping when a tornado relocates their home from Kansas to Oz. NOAA sounded a timely alert, but they didn't hear it because they thought that the alert on their Uniden scanner was too loud and had used the option you suggest to turn it down. Their heirs hire an attorney to determine whether they have any possible redress and he/she can't think of anyone that's still alive to blame other than Uniden so suit is commenced against Uniden and its various officers and employees. The jury is composed of the neighbors of the deceased who survived the tornado because their warning devices woke them up. You'd be willing to pay all of Uniden's legal fees and the possible judgment granted by neighbors of the poor deceased family? And you're willing to do this because you want the alert tone to be less loud?
Sure thing.
I've seen far less meritorious lawsuits result in verdicts for the plaintiffs. This isn't even much of a stretch.
Dick
SLJ2137694
Lehighton, PA
Dick
I was thinking along the line of my not holding Uniden liable for for a loss I incurred because of my not hearing a warning because I turned the volume down. Of course in this world it isn't that simple. The probability of others using the legal system to bring an action against Uniden is far from remote.
