BCT15X: BCT15X Programming Cable
bob5731
USA
I have a BCT15X and a PRO107. Can I use the pro 107 cable on my BCT15X to program it in windows?
What free programming software for Windows can I use to program my BCT15X?
Whiskey3JMC
Simulcastylvania, TE
N9JIG
Sheriff
Moderator
Far NW Valley
No, they require different cables. You can use a USB-1 or similar cable for the front panel serial port or a DB9 type on the rear panel. Amazon.com should work, there are other third-party ones as well. You can also use the serial cable that came with the scanner with a USB to Serial adapter.
FreeScan works with the BCT15X, while no longer supported it should still be able to be found.
bob5731
USA
the cable I have is a DB9 RS‑232 serial my ThinkPad 11e done not have db9. I would like to the scanner program today.
mass-man
trying to retire...
Parker Co., TX
ProScan works great for me on BCD996P2 and BCT15X! I don't change the programming often and have to remind myself how ProScan works but it has been a good $50 investment. If you are thinking of programming once and leaving it that way, there is a 30 day free trial with Proscan. But I bet after you use it a few times you will go ahead and buy it...BTW that's $50 just once...no charge for upgrades.
hiegtx
Mentor
Dallas, TX
Just to add a bit to what mass-man noted, ProScan @ $50 includes programming, logging, & virtual control, plus it also supports a large number of other Uniden scanners. ARCXT, the "Basic" version is $40, but only covers programming &, I believe, logging. It does not allow virtual control of the scanner. To get that functionality, you would have to upgrade to the Pro version @ $70.00 The ARCXT software, unlike ProScan, supports a limited number of scanners. In addition to the BCT15X, it also can be used for the older 396XT, 346XT, & 996XT, as well as the 325P2 & 996P2.
bob5731
USA
yes it has a USB-A connector. ware can I get free frequencies?
mark40
Pike County, Pennsylvania
Agreed, ProScan is the best investment I've made to supplement my scanners
Whiskey3JMC
ProScan and ARC-XT both work great but cost $50 and $40 respectively.
Definitely recommend Proscan over Freescan as the latter has become abandonware at this point (no updates in over 10 years)
Also "basics" is non-possessive when used in this case (plural) & I support developers who use proper grammar/punctuation :ROFLMAO:
Whiskey3JMC
If you let us know where in the USA you're located we can direct you to the proper RR database page & point out any potential pitfalls which may hinder your scanning experience (encryption, simulcast distortion, others). Also your BCT15X will only handle analog frequencies so you'll need to be certain your area's ops are still analog. Otherwise you'll need to upgrade to a digital scanner
bob5731
USA
Norman, ok. I can not get the scanner work with 9 pin cable using windows 11
buddrousa
Google setting Baud Rates on a PC
  1. Open Device Manager: Press Win + X and select Device Manager, or search for it in the Start Menu.
  2. Locate COM Ports: Expand the "Ports (COM & LPT)" section.
  3. Access Port Properties: Right-click the COM port you're using (e.g., COM3) and select Properties.
  4. Adjust Settings:
    • Go to the Port Settings tab (for basic settings).
    • For more advanced options or if settings are grayed out, check the Resources tab, clear "Use automatic settings," and then modify the settings.
  5. Match Your Device: Set the Baud rate (e.g., 9600, 115200) and other settings (Data bits, Parity, Stop bits, Flow control) to match the device you're communicating with.
  6. Apply & Restart: Click OK, then restart the device or application.
For Applications (Software Method)
It is also in the 15/15X easy to read manual.
merlin
DN32su
I have the front USB programmiing cable for my BCT-15X. Now I thought it is a proprietary cable, it has a unique connector similar to a camera.
It worked with Proscan, the better, or Freescan (free). Still a learning curve programming but really good analog only scanner.
