BCT15X: BCT15X programming
noeclym
ahwahnee, ca
Does anyone have a contact phone number for FreeScan? or a work around for the program with Windows 11? The program through Windows 11 does not like the cableing connection between the scanner and the computer. Thanx Don
nessnet
What month is it?
Did it work properly in previous versions of Windows (10)?
There shouldn't be any appreciable difference in P&P / drivers between them.
Suggesting something else.
Look at device manager - what do you see?
Maybe try and re-do driver.
(Delete and re-install)
Also maybe try a different port to eliminate it being the problem.
ProScan
Software Provider
Ontario, Calif.
This does not sound like a FreeSCAN problem.
Are you using the front or rear port on the scanner?
Does the Win Device Manager show the port as working?
noeclym
ahwahnee, ca
Did not have 10, just downloaded freescan a couple of weeks ago. I see a com ports driver, but don't know what that means, not real techy.
thanx for the response
W
noeclym
ahwahnee, ca
Not a techy person, don't know how to use device manager
737mech
Clark County, NV.
Did you try these steps? In freescan press the download from scanner button, then on the comm button left of the start download button, then start auto button. This
will make freecan look for your scanner.
wtp
Port Charlotte FL
noeclym,
i sent some instructions on how to program manually, it really is not hard.
look at the top right of this page for a little envelope and click it.
wtp
Port Charlotte FL
he is blaming windows 11 not working with freescan and also said he will not monitor this thread anymore and passed on his thanks.
