JackSmith102
- Joined
- Jul 28, 2006
- Messages
- 14
I've had my BCT15 for about a week now, and like it very much. However, I have noticed something strange when comparing it to the BCT7. For example, I tuned in to a sort of radio station on the BCT7 that was at 806.3375MHz, and then tried doing the same on the BCT15. Oddly enough, whereas the BCT7 would pick up the station's broadcast, the BCT15 just played static.
I then tried to select AM, FM, NFM, WFM, and WFM (Broadcast) bands on the BCT15 with the same frequency (806.3375MHz) to determine if it was simply the wrong band. No such luck. It still played static. How is it possible that the older scanner would pick up the radio signal, while the BCT15 would simply play static?
I also tried swapping the antenna that the BCT7 was using and tried it on the BCT15, and still the same thing.
Any ideas?
Any ideas?
