BCT8 speaker problem ????
BUCKKO
Lakeview
Have two of these. One in the truck and the other here on the base. ::pROBLEM.. WHAS WORKING GREAT, SHUT IT OFF CAME BACK LATER TURN THE SCANNER ON "NO SOUND". TOOK IT APART ALL LOOKED OK SPEAKER SEEM TO LOOK OK. PLUG IN AN EXTERNAL SPEAKER WORKS GREAT. DO NOT REALLY WANT TO HAVE TO RUN AN EXTERNAL SPEAKER BUT MIGHT HAVE TO. HAS ANYONE HAD THIS PROBLEM OR KNOW WHAT I MIGHT DO TO FIX IT? ALL THE REST OF THE SCANNER WORKS GOOD.
Thank you
Buckko
davidmc36
South East Ontario
Even though the speaker may look fine the tiny wire in the coil may have gone open circuit somewhere that you cannot see it.
Or it could be the external speaker jack. The contacts that are supposed to close back up to pass the audio on to the internal speaker when the external speaker is unplugged could be dirty or bent and not making contact.
Depends on if you use the external jack very much or not.
But since you described it as all of a sudden no sound when you turned it on then I am leaning toward a spike in current in the speaker when you turned it on.
Get the particulars from off the speaker and they should be fairly easy to match-up at a decent electronics store and probably not expensive.
BUCKKO
Lakeview
Bct8 ??? Sound
Thank you Dave. I use ex-speakers on almost all of my units. This one I took out of the truck set it on the shelf and was there about six months or so. IF I WERE TO PLUG THE SPEAKER FROM ANOTHER SCANNER IN THE SOCKET WHERE THIS PLUGS IN AT INSIDE WILL THAT HURT? i WILL GIVE IT A LOOK AND SEE IF IT MIGHT BE DIRTY.
Thank you for the HELP.
BUCKKO
davidmc36
South East Ontario
If it came out of the truck and then sat on the shelf for six months some corrosion sure could have formed on the speaker jack stopping the internal from working. If you have a spare scanner speaker that works it would be fine to swap it out to test.
BUCKKO
Lakeview
New post need help bct-8
Replaced speaker works GREAT Now... Thank you all .Got another question ?
OK I HAVE ANOTHER BCT-8 IN A 2000 DODGE RAM W/CUMMINS 5.9L. I SEEM TO GET A LOT OF STACTIC ..I HAVE ALL NEW COAX FOR THE SCANNER ANTENNA.. AND AM PRETTY SURE THE SCANNER HAS A "GOOD" GROUND BUT I DO HAVE IT HOOKED TO THE FUSS BOX SO WHEN I SHUT THE TRUCK DOWN THE SCANNER AND ALL THE OTHER RADIOS ETC IS SHUT DONE OR OFF ALSO... BUT GET A LOT OF STACTIC ALMOST LIKE THE STACTIC YOU WOULD GET ON A GAS ENGINE... ( i don't think it could be the plugs LoL) ANYWAY IF I SWITCH THE HOT WIRE AROUND TO ANOTHER PLACE WOULD THAT HELP? ANY HELP FROM ANYONE...
THANK YOU FOR ANY HELP.
BUCKKO
Houston, Texas
I have had the same problem with older scanners. A good radio repair man told me the speakers they use are not very good quality. Radio Shack has replacements.
