Bearcat 996t
Coop62
How do you program p25 trunk system in this. Scanner for w va
hawkeye32
Windsor
Hi Coop, Welcome to RR!!!!
Best to download a software that can program ur scanner. You can get free ones such as free scan, or you can try here Software for Uniden HOME PATROL HP1 HP-1 PRO-700 Radioshack GRE GRECOM MFJ DSE AOR police scanner software BCD996XT BCD396XT BC346T BCT15X PRO-404 PRO-405 PRO-97 PRO-96 PRO-2096 PRO-106 PRO-197 PRO-164 PRO-160 PRO-162 psr500 psr600 psr300 psr400 psr1 .
You get a free trial period on the butel software, it would be enought o get ur scanner setup, and try the different functions of the software and then you can choose to buy or not.
Bubba1661
WV DB Admin
Charleston W.V.
Hey Coop62, Welcome to RR. Where do you live in WV? If you need help just let me know.
maalox
n y c
carefull using headphones on the 996t is known to break the internal speaker on this scanner.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It's not the internal speaker that breaks, the phone jack is the real culprit. That's where the connection gets shorted as it's cheap...
Coop most folks use the freeware FreeScan to get started - then if you want you can migrate to ARC996 or ProScan later. You have lost nothing by doing it this way as it's free.
This article in our wiki has links for just about everything you will need to understand to work with this radio (including the link for FreeScan and its user guide, which is also hosted in our wiki).
Program your DMA Scanner - The RadioReference Wiki
Note that anything blue is a link...HTH...Mike
bear780ks
Central KS
The Front headphone Jack is Weak this is a first heard for me as i didn't know anything about it). What about the Rear Speaker Jack on the Back of the Radio is it the same Way i always used an External on my BC 780 and i have one on my 996 a Radio Shack but i want to get a Uniden one very Soon but thanks for the Info that was put on here..
And i guess i will take even better Care when connecting and Disconnecting to it.. Ra
wmbio
Cumberland, Md
The entire state of WV digital system is programed into the scanner from the factory. To get you started while the scanner is scanning press (.) 4 5 to turn on Wvirginia wvirp.
Enjoy
Wmbio
