Decode ARC4 encryption (WITH KEY DATA) with SDR
knockoffham
Michigan, USA
I'm president of the amateur radio club at my university. I am working on a project that might turn into another member's research project if I can do this.
1. Are there any SDRs and associated programs (preferably open source) that can decode conventional P25 that's encrypted with ARC4/ADP? They key would be known and passed to the SDR/program. I am not a noob asking to decode encrypted traffic without a key. This is in a controlled environment.
2. Or, are there any programs I can use to generate and/or decode a complete P25 bitstream without using any RF at all? Preferably one program/computer to generate the bitstream, into a file, and another program to attempt to decode it. Would be cool if we could encode/decode voice but not necessary. If no such thing exists, we will probably use a P25 radio at low power into a dummy load going directly into an SDR or perhaps some intense attenuation and then through a coax cable. Thanks
knockoffham
Michigan, USA
Great. Those all sound like the exact sorts of things I am looking for. I will do my research on those. Thanks so much!!!
WV8VFD
You might also take a look at DVM Project as well. You could set up an FNE and DVM Console. If you connect the console to the FNE you can generate P25 with no RF. If you turn debugging on you will get full hex dumps of the P25 frames. If you throw in an MMDVM hotspot and a Pi (or USB board) you could generate a P25 signal with minimal (10mW I believe) RF and then decode it with an SDR. IIRC dvmconsole supports ADP, DES, and AES.
knockoffham
Michigan, USA
Great. Was considering playing with MMDVM anyway
Sq5tm
Być może zainteresuje Cię również jeden z moich projektów pobocznych, Cryptings . To w zasadzie zestaw prostych narzędzi do generowania i stosowania strumienia klucza, wraz z opisem i przykładami z zasobów FIPS i NIST.
What program are these arc4 key extraction projects in?
Forts
Ontario, Canada
If the author wanted it in the public I'm sure he would have shared a link in the YouTube video. That was more of a "look what I have that you don't" type video. Anywhooo..... Things of that nature aren't typically discussed here, and we are veering away from the original intent of this thread.
