Bearcat 996XT Profile
chrisb480
Good Afternoon,
My knowledge of scanner programming is minimal, I typically stick to Unication products. However, I have obtained a BearCat 996XT base scanner that was programmed sometime ago and I believe the programming to be outdated. Updated the control channels manually for Balto County, still not receiving any traffic. Does anyone have a profile they can send me that I can plug into this scanner? If not, any direction on how I can program this via a computer and RR Import would be very helpful. Firmware is 01.07.03 (probably very outdated). Note, I am located in Harford County. Thank you.
chrisb480
Just learned this model is not capable of phase 2, so I am afraid it is no good to me. Thank you for the replies.
tvengr
Well Known Member
Baltimore County, MD
Baltimore and Harford County systems are both P25 Phase 1 which can be received by your scanner. Both counties use simulcast systems which may give you receive problems depending upon your location. At my location, the SDS100 and SDS200 are the only scanners which will work. I use Butel ARC-XT Basic software to program my BCD396XT, BCD996XT's, BCD325P2, and BCD996P2. I have ARC-XT files for Baltimore and Harford Counties and will be happy to share them with you. I will be sending you a PM. When you see a red envelope next to your name in the upper right area of the page, please click on it.
chrisb480
Thank you very much!
wtp
Port Charlotte FL
i will wand a personal message with other things to scan for.
that should have been, 'i will send a personal message', i should not type in the dark...
look for the little envelope at the top of this page.
tvengr
Well Known Member
Please click on the red envelope next to your username in the upper right area of the screen. I have a personal message for you.
