Bearcat not transmitting
bailagent67
Michigan / Isabella County
I have a BC 980. It's receiving with no problem.
I checked all of my settings over n over. Just can't talk to anyone.
Radio about 4 years old. All lights work.
Antenna is a Stryker, about 2 years old.
Mic is brand new, factory Bearcat.
Any tips
slowmover
Fort Worth
Haven’t used my U980 in a long while (can’t remember if all these present):
Mic gain turned up?
RF power turned up?
Other microphones work okay?
Coax tight in SO-239? (And at antenna).
Nothing loose on antenna (coax not broken/crushed).
Indicator on panel shows RF output?
Voltage Meter shows change at key-up?
Wiggle mic cord to look for changes
Wiggle coax to look for changes.
(Don’t hold key down if “short circuit” found).
bailagent67
Mic gain turned up?
RF power turned up?
I will check your suggestions today.
wtp
Port Charlotte FL
and adding to slowmover
this should show open, no needle movement.
images
center to ground.
bailagent67
Update - although I'm not finished.
Coaxial cable was fine
I unscrewed the base of the antenna, lots of moisture was present. Dryer it out, cleaned it, and put Dielectric grease on it.
More updates soon
robertwbob
KE0WRU
Northeast jasper county,missouri
More updates soon
might as well buy new coax.and use that self vulcanizing rubber tape .wrap from bottom of pl 259 where it goes to antenna. then when thats done use 3M tape and wrap from bottom up again but go oppisite direction you went with the rubber tape.
niceguy71
Massachusetts
I hear a lot of the Stryker antenna's get water in them and short out... I wonder if that killed the transmit part of the radio??
robertwbob
KE0WRU
if you got a late 980 and screen is good i got a 980 that transmits fine but screen died down to where its worthless in my truck id prolly part with for a few $$$.
my new McKinly came in last nite and will remove the 980 this week.
i think its just an undo ribbon cables and few screws n back in buisness. if you can press a button and shut beep off its new version
