BCT15X: Bearcat scanner bct15x
stuart3009
Need help
I’ve just bought a bearcat scanner bct15x downloaded free scan and for some reason I’m getting an error stating
Could not establish connection with scanner
Com port settings are com6
Port 115200
When I use the auto start detection that’s when I get an error I’ve bought a cable attached to this question am I doing something wrong
ProScan
Software Provider
Ontario, Calif.
Is the cable connected to the scanner front port?
In the Device Manager, see if COM6 shows in the Ports section.
stuart3009
Yes it’s connected to scanner front port that was the cable I was told to use unless my laptop is broken but it will pick up comport 6
N1EXA
FT8 Huntin Mudd Duck on the deep end of the pond !
Acushnet Heights New Bedford MA - GRID FN41 mp
Did you in Free Scan assign it to Comm port 6 ?
At the read from Scanner square - Thats when you click on the radio with the Down arrow !
In the middle there is a square with the commport and speed if you click on that you can re assign it.
The USB to Com Port adaptor you have may not be USB Version Compatable with your version of Windows ?
You could test the adaptor in Hyperterminal and see if it picks it up there.
What version of Windows are you trying to do this in ?
Just some idea's
Petye N1EXA
Kiniutech
Past login as: questnz
Somwhere in the South Pacific
Hi if I remember correctly you cant have connection above Com 4 in Freescan ? I am not 100% sure here
Try remove all other ports restart PC and in Device Manager check what Com ports you got.
Long shot but worth trying
