Bend radius
JamesBrox
Santa Rosa County, FL
What's the bend radius on 1/2" hardline coax. Doing research, I seen 5" max. But I wanted to ask y'all? Thanks
tweiss3
Is it time for Coffee?
Ohio
Check the manufacturers specs. It usually lists a 1 time bend radius and a multi bend radius
dcr_inc
Not an EXPERT !!
Delta, Pa
It depends on the manufacturer.. Is it Heliax or Super flex?.. Check the MFG webpage
JamesBrox
I did. But wasn't quite sure what it meant. Single bending 2.8", Repeated bending 4.7". So basically, if I bend it at 3" roughly one time, I'm fine....no damage. But I keep the radius' at 5", roughly, I can reroute as much as I need to, w/o damage.
That's what the spec says. Remember, its radius...
Apparently.
But I'd say give it more room. Yes, according to the specs you can bend it that tight, but it's challenging stuff to work with, and if you go to far, often the outer shield will kink, and then you are stuck. I don't think I'd ever bend 1/2" hard line that tight.
There may be better cable choices. How long is your run? If it's relatively short, or this tight bend is close to one of the ends, you might want to use a length of SuperFlex and use the hardline for the rest.
JamesBrox
Apparently.
Yes sir, advise greatly appreciated. WRXU693
JamesBrox
[/QUOTE]
50'
If you really have to snake this through residential type walls, then you may want to reconsider. I've done it in my own home, but I had to use a 90º connector on the end to stub into a wall jack.
If a bit of additional loss is tolerable, the FSJ4-50 "superflex" cable might be a better choice. It'll bend in a smaller radius and is much easier to work with in tight spaces.
It does require different connectors than the non-superflex stuff, though.
If you don't mind installing your own connectors, it'll be easier to install and less expensive than what Bridgecom is selling:
JamesBrox
I may have to go that route, I'll see. My shack is a stand-alone building. So, all I'm going through is one exterior wall to the outside. No major navigating. I looked at those links before I ordered the Bridgecom cable. Only reason I didn't, is because I'd have to put the connectors on myself. I don't have/didn't want to buy a stripping tool/bit for just two connections and I trust myself to do I quality job at terminating.
The tools make life easier, but they are an expensive investment for just two connectors.
I've installed many Heliax connectors just using a razor blade, a hack saw, and a small file to chamfer the end of the center conductor. Wouldn't fly in the professional world, but was just fine at home.
JamesBrox
I get it. I can do it but I wouldn't know how far to cut back each layer.....ect. Then if I did do it and put in service and the SWR is sky high......it wouldn't be a good day around here for me or my family....LOL.
Connectors come with the measurements.
But I totally get it. Sometimes it's better to just buy what you need and not mess with the details. You may have to search around for someone who will make superflex cables for you. If you can find them, the regular stuff will work, you just need to give yourself enough space to get it routed.
JamesBrox
50' will work. Reason I know is that the hardline is replacing already existing LMR400 for my GMRS repeater. Same antenna location and same repeater location in the shack. So, I think I'll be ok. I've gradually figured out the LMR400 is not a good cable for repeater use. Live and learn.
Yeah, that's one of the issues with the LMR grade cable. It'll work if it's kept perfectly dry and never gets damaged, but not the right choice.
1/2" Heliax should be a good improvement for you.
If it wasn't so expensive to ship, I'd offer to build the cable for you. Unfortunately it's a bit bulky and the shipping would kill ya'.
JamesBrox
Appreciate that offer.... mighty nice of you. Shipping cost are outrageous. Anyway, thanks again and Merry Christmas to you and yours.
WRXU693
