bending dipole "arms "
anneranch
the radiation pattern of common dipole is "donut shape"
For sake of argument - the "arms " of the dipole are "in line" or
180 degrees in relation to each other .
When this relation angle changes - measured on "narrow " side
to 90 degrees - how does the radiation "donut" changes ?
I would be more that happy to ask Mrs Google,
but have no clue how to formulate my question.
prcguy
It sounds like your asking about the radiation pattern of a classic dipole to something like an inverted V where the elements are no longer parallel and in line with each other. Here is someone that modeled such an antenna with the resulting image.
anneranch
As much as I tried to explain what I am asking - i have failed.
No, my question is not about inverted v - I am asking how the radiation pattern
will change when both elements are still in same horizontal plane.
Let's s call it ":horizontal inverted v " .
i also neglected to add , as in my other post, I will eventually do modeling,
i asked here in case somebody knows a simple answer or there is a link.
prcguy
I've failed to understand the question. If you start with a dipole with both elements at 180 degrees to each other, that to me sounds like a "conventional" dipole. If you change the relation angle to something other than 180 degrees it seems it would become an inverted V throughout most angles from 179 degrees to 90 degrees. Does your question fit within that description or is your proposed antenna outside of those bounds?
gh6406
Dalton,Ga
I believe the OP is questioning as if looking down from above, that the "legs" are no longer straight, or 180 degrees. Maybe picture inverted V on it's side?
anneranch
Yes,. inverted V on its side is the best description .... or "the height of the elements is constant ".
I have been asking Mrs Google and so far no success...
anneranch
That would be a V dipole..
Best definition so far.
However - I thought that "dipole" is where "h = lambda/4 " .
As presented , h varies , therefore it is NOT Vee dipole .
And since h varies , then the alpha and D cannot be calculated as presented either.
But getting closer... Still antenna modelling IS the ultimate answer.
anneranch
Found this
Some surprising conclusions / observations .
Not sure about " Effect_of_Various_Angles_of_V-shaped_CPS_on_the_Antenna"
Missed definition of "CPS "...
Interesting to note how they measure the "alpha" angle.
It almost looks as the half alpha - going from zero to 90 degrees has very little affect on directivity of the atenna.
