Benton County/Corvallis... ???
joescanner
Just another radio geek.
Gresham, OR
Okay, so spending some time watching OSU vs Arizona today, and playing with the 396XT... Someone was spreading a rumor that Benton County was using conventional P25 on and off... well, today it seems to have been off.
However, what I find interesting is that I'm hearing both the dispatcher and the mobile units on both the reported repeater input and output frequencies. On the input side, I'm not seeing any tone; on the output side I'm seeing several different DCS tones (143, 174, 205 are the ones that stick out in my mind).
There doesn't seem to be any rhyme or reason (at least to me) which tone is used for which unit; I heard both 400 and 800 units and they all came up with the various different tones; the dispatcher when responding always used the same tone as the unit they were responding to.
Anyone shed any light? I'd like to get the benton county database cleaned up...
Columbia Co. OR
Someone chimed in on one of my other posts and said Benton Co will be going all Digital in Fall of this year. I was in the WA forum but I could find nothing at that time that said they were. Could the Benton Counties (WA & OR) be getting mixed up in peoples posts? I don't see any Dig listed for either in the RRDB and I've had no problem hearing Benton Co WA when I'm there. Thanks for all you do here Joe.
Baker845
Oregon
The three different rx DCS codes are for the three repeaters that are uses in Corvaills area. The 143 DCS rx tone is for the Vinyard repeater that Corvallis PD uses and the other two DCS rx tones are for other two repeaters used in area. The other repeaters are in Wren and North East Albany. Benton county and Corvaills use 155.490 and there are 4 repeater sites that benton county has on 155.490. The 155.490 repeaters are mix/mode repeaters which means p25 can be used at any time on any repeater,but most all of the time there in the clear. 154.340 is fire repeater used county wide and has repeater on Vinyard for city and Marys Peak for rural areas.RX tone for 154.340 167.9.
mikepdx
Corbett, OR USA
Anyone know what would be the point (purpose) of using
P25 sometimes and analog at other times?
Are they testing, or are they attempting to limit reception of certain transmissions?
or are the P25 radios only in some vehicles?
or are they switching back to analog when necessary to overcome a poor transmission on digital?
Some other reason?
Who makes the decision to use P25 at a given moment? Dispatch or the Mobile?
Why not full time P25?
I'm puzzled.
mikepdx
Corbett, OR USA
BTW - Anyone know anything about this?
"Linn and Benton Counties plan to acquire and deploy two 700
megahertz (MHz) communications sites to support a trunked radio system that will serve over
40 agencies, including all of the local fire and law enforcement agencies, county and city public
works departments, local transportation functions, and Oregon State University (OSU)"
I found the info in this document:
Public Safety Interoperable Communications Grant Program
Improving Interoperable Communications Nationwide:
Overview of Initial State and Territory Investments
November 2008
the PDF doc:
http://www.ntia.doc.gov/psic/PSIC Investment Data Analysis (report and appendix).pdf
joescanner
Gresham, OR
It's certainly possible. I don't follow much from Washington (although I do check the forum out once in a while, and will catch the odd submission that Lowboy misses...) so can't speak to what may or may not be happening there.
I'm still confused by why I was hearing both sides of the conversation (more often than not, but not 100% of the time) on both the repeater inputs and outputs.
The digital thing is just a "bonus" - i had read somewhere that Benton County was using P25, but had never heard it...
I've added some info that I found while doing some research on this to the wiki.
Benton County (OR) - The RadioReference Wiki
joe
joescanner
Gresham, OR
From what I've been able to gather, it's merely a side-effect of an infrastructure upgrade that occurred; the new repeaters and portable/mobile subscribers are P25 capable. Everyone seems to be happy with using analog, so they haven't changed over.
Don't think #1 applies at all; #2 might apply in some cases, and #3 would be likely, if they were primarily on digital to begin with.
Some other reason?
I'm puzzled.
I'm puzzled too, and can only speculate that they have special orders come down from the chief's office (or something like that) that say "we're going to test the digital side of the radios today". From what I've been able to gather, the radios have both a conventional analog bank and a conventional P25 bank, and the repeaters will pass both.
Not using digital full time may have to do with interoperability with other surrounding agencies.
joescanner
Gresham, OR
November 2008
the PDF doc:
It's probably a part of OWIN. But thanks for that link, that's an interesting document...
Net-5
November 2008
the PDF doc:
Yamhill county wanted to do the same thing around 10 years ago (trunked 700MHz), but they lacked the funds to pull it off. I wonder how Linn and Benton counties can afford this now, help from the feds?
joescanner
Gresham, OR
Oregon Electronic Order of Battle
Can anyone confirm if any of the following information is still valid? (Yes, I know I just posted updated corvallis pd id numbers to the wiki, but aside from that...)
Code:
                           BENTON COUNTY FREQUENCIES
  GO BEAVERS!!
155.490--Benton County (Corvallis PD) Sherriff Dispatch
156.090--Benton County (Corvallis PD) Sheriff Dispatch
155.010--Benton County Talkaround (CH 4)
155.070--Link to Lincoln County
857.9625-Corvallis Police Mobile Data Terminal
812.9625-Corvallis Police Mobile Data Terminal (Mobiles)
155.625--Benton County Sheriff (Licensed but not used)
154.665--OSP Albany area
155.745--Oregon State University (OSP Unit)
155.925--OSU Project Saferide (An after hours "Shuttle" for women)
453.875--OSU Security & Parking (Not OSP)
154.340--Benton County Fire Dispatch
156.195--Corvallis FD Ops channel
154.220--Philomath FD Ops channel
155.340--MedicLink to Good Samaritan (Corvallis)
154.280--State FireNet
155.805--Benton County SAR
155.160--Corvallis Mountain Rescue
151.175--Oregon Dept of Forestry-Philomath Dist.
162.610--Siuslaw National Forest-Corvallis HQ
165.975--BLM-Salem
Other Misc stuff below
Benton County Fire, All fire dispatching is done on 154.3400 Mhz. And to
identify the different departments are as follows,(including law)
  Sta.# 100 Corvallis Fire Dept.
        200 Philomath Fire Dept.
        300 County Rd. Dept.
        400 County Sheriff
        500 Hoskins/Kings Valley Fire
        600 Blodgett/Summit Fire
        700 Alsea Fire
        800 Corvallis Police
    890 Corvallis Parking Patrol (894 most common)
        900 (Not assigned)
        1000 (Used to be Monroe Police)
        1100 Philomath Police
        1400 Adair Fire Dept.
        1700 Monroe Fire Dept.
Corv. and Philo. Fire Dept. numbering system;
   Corv 101 to 109 - Station ID,ie 101-Main sta. at Fifth St., 102-sub sta.
   at 35th., 103-sub sta. at Circle, 104-sub sta. at Tunison.
   Philo 201 to 209 - 201-Main sta. at Main St., 202-Sub sta. at Wren Rd.,
   203-Sub sta. at Llewellen Rd.
        110 to 119 - Dept. officers.
        121 to 129 - Ambulance and Medical units
        131 to 139 - Engine Companies
        141 to 149 - Water Tenders (tankers)
        151 to 159 - Truck Companies
        161 to 169 - Utility Units, Brush rigs and etc.
        171 to 179 - Special Duty Apparatus, Dump Trucks, Flat Beds and etc.
        181 to 189 - Haz - Mat and Rescue Apparatus
        191 to 199 - Staff Vehicles
        Note- The last digit in the ID # indicates which station that unit
    is from. Example, #232, Philomath Engine Co. from station 2 at Wren Rd. Dept
    officers are the only exception to this rule.
Monroe Fire Units (Dispatched Via 154.34)  (Big Thanks to Randy Younger for the
info).
1710 fire pickup  1711 pumper     1712 pumper
1713 tender       1715 medic unit 1716 command van
1721 pumper       1722 tender     1725 medic unit
1731 pumper       1735 medic unit
All trucks that end with the teens are from the main station in Monroe,
the units ending with 20's are from the sub-station in Alpine, and the
units with 30's are from the other sub-station in Bellfountain.
        Philomath FD will be using ODF's 151.175 part time this
    summer
        Benton Co. dispatch center does not have Philomath FD's 154.220.
    This is licensed to PFD only.
Hewlett-Packard
462.2125 462.4125 467.2125 467.4125 462.3500 451.725 464.5 464.55
935.9125 936.4 936.9 936.975 939.5125 461.0625 463.4 896.9125
897.4 897.9 897.975 900.9625 929.5125
OSU-
461.4375- Football Team (Practice Co-Ordination)
452.425 - Some type of Motor Pool
461.5625- Plumbing
453.5250- Facilities
453.3375- Telecommunications
464.8250- Memorial Union (?)
461.3875 462.0875 463.2125 463.6375 463.9875 464.2375 464.4375
463.400 464.825 466.3875 466.4375 466.5625 467.0875 468.2125 468.400
453.4375 453.525
 One of these freqs belongs to the Memorial Union but when I hear it I've
been too busy to note the channel
Baker845
Oregon
Heres some changes i know of for you Joe. I think all unit ids ect. are same but not 100% sure.
155.010--Benton County/Linn countyTalkaround (CH 4) Know as Tri-County Net
155.070--Lincoln County Sheriff repeater
155.925--OSU Project Saferide (An after hours "Shuttle" for women)?
158.820--Corvallis FD Ops channel
155.340--MedicLink Good Samaritan (Corvallis)
154.280--State Fire Net
151.1675--rx pl 167.9 (Narrowband)Oregon Dept of Forestry-Philomath Dist.
163.375 rx PL 103.5 (Narrowband)--Siuslaw National Forest-Corvallis HQ
171.675--BLM-Salem
Sta.#100 Corvallis Fire Dept.
400 County Sheriff
700 Alsea Fire
900 (Not assigned)
info).
Hewlett-Packard
OSU-
461.5625- Plumbing
453.4375 453.525
been too busy to note the channel__________________
