Bernards Twp. Police
djk
NJ
Is Bernards Twp. police active on the p25 phase 2 with TIG 703, 705, 707 primary control 500.8875? I have an RTL-SDR setup and hear other agencies but nothing so far for Bernards.
GTR8000
NY/NJ Database Guy
BEE00
It's actually one system, not two, which operates two simulcast cells (aka sites) in different bands. ;)
djk
NJ
Does that require an additional RTL-SDR or just add the second system to the trunk.tsv file? I have tried putting a second line but sticks on the last line and does not alternated between the two entries.
rr60
Are you local to Bernards? How active are the region 1 Police TIGs?
Region 1 is active. The County simulcast TRS System as @GTR8000 points out has two sites, (3) 500 & (4) 700.
Bernards traffic mostly resides on Site 4 700 (MHZ). In Bernards there is a simulcast site (4) located at the PD headquarters. Most subscribers affiliate with this site.
Region 1 carries North County traffic with the exception of Bernardsville.
djk
NJ
@r60 I am in Basking Ridge (Bernards) and now have the RTL-SDR on the Pi receiving some activity on TIG 703 on the (3) 500 site. I am not able to get it to on the (4) 700 at for any TIG. Since it is a simulcast system I shouldn't be missing anything using the (3) 500 site, correct?
rr60
It is a long journey. This is not a spectator hobby as some have noted in their Avatars. I believe all your questions will be answered if you search the entire NJ forum “Somerset County”. Maybe even Bernards.
Keep in mind and also look for previous comments the Sites 3 & 4 are all not collocated.
Just because you receive Site (3) does not guarantee you will hear Site (4).
Be sure to look for posts about subscribers and how they affiliate as well.
robbinsj2
Bridgewater, NJ
@r60Since it is a simulcast system I shouldn't be missing anything using the (3) 500 site, correct?
Think of the sites as each simulcast on their own but not simulcast with each other. In other words, if you hear it on 500 then you'll hear it on 500 throughout the county (subject to reception quality); if you hear it on 700 then you'll hear it on 700 throughout the county. Some talkgroups are active on both sites in which case you'll hear everything for that talkgroup on both sites but that isn't always the case for every talkgroup. It will depend on whether a radio has tuned it in on the particular site or if it's set to simulcast (would be a minority of talkgroups at most).
rr60
I checked the CC in use for you. It is the primary 774.40625 in the DB. If you are in Basking Ridge that should be line of site to Site 04 at Bernards PD. If you are on a side of a hill that blocks path maybe not.
djk
NJ
Thank you for the replies. @richee2000 that is good to know that part of the problem is the reception which will make tuning the pi op25 setup challenging.
rr60
I would suggest if you are able, taking you pi setup over to the site by the Police Department in Bernards. You will have 100 percent signal. Go from there.
rr60
Could have had a bad power amplifier I suppose. I have seen that before. I do not believe the systems are monitored in Shaumburg anymore. Anything is possible.
richee2000
Monitoring NYC from Sea Bright NJ, East Hanover NJ
The interesting thing was it was only the data channel that was low signal. And of course if you can't decode the data channel you can't decode the audio on the other frequencies.
Dunellen, New Jersey
I noticed this yesterday as well. 700 signal used to be spotty down here in Raritan/Somerville area with alot of distorted audio. Now It's pretty good and I've been listening more to the 700 side. Now It's the 500 signal that's being weird and distorted. I assume eventually everything will be moved over to the 700 side. 500 is pretty quiet as of late.
richee2000
I'm not sure if this is all because of propagation or because of antenna issues or Tower issues or weather...
I was in Hoboken and Midtown Manhattan over the weekend and I was still getting a fairly decent 700 signal from Somerset County. At times it was a little iffy but I could still make out most of what they were saying. So in the east, the signal is very strong.
