What is the best Ubuntu version for OP25?
Just got a Raspberry Pi 5 but am also interested in an Ubuntu package for a Dell laptop.
OMG, I am so sorry, "DragonOS" DragonOS – Software Defined RadiosSorry, never heard of DemonOS. What is it based on?
To expand on my original answer, I would observe that since I use Linux Mint for my day-to-day work, op25 is going to be most compatible with, and easiest to install on, any of the Debian based distros.
Whenever there is a major architecture change, such as the move from SWIG to PyBind that came with gnuradio-3.9, I end up spending considerable effort with testing the install script and executable across as many distros, releases, and architectures as possible. Mint/Ubuntu/Debian are really popular distros so these get worked on first (under amd64), then I check if Raspberry PI OS is happy. Only then - if time permits - do I look at the less-common distros such as Arch, RedHat/Fedora, and anything else I might be asked about.
I am so VERY sorry, I meant "DragonOS": DragonOS_FocalWhat is the best Ubuntu version for OP25?
Sorry, I can't help with Osmocom version. Suggest you reach out to @OuterdogI'm trying to get OP25 Osmocom version running after installing the most recent version of Ubuntu on my laptop. Is there a trick to getting it to run?
I would normally run the command line in the terminal and fire up the browser with the URL to get it working.
I had it running on an old version of Ubuntu but saw some messages about others having issues after upgrading.
Thanks for any help.
Just rebuilt an install with this and it works like a champ. Much easier that other OS's and all the drivers, etc. seem to work well. 2 thumbs up! Thanks for the recommendation!I am so VERY sorry, I meant "DragonOS": DragonOS_Focal
Lubuntu based, has everything you need to get going.
