Baofeng BF-V12D Transceiver
h_milsom
England
Has anyone managed to get the Programming Software for these radios please?
Thank you ...
h_milsom
England
And miss the thrill of the chase? Never!
Software found.
PS The link is unavailable to the uk …
h_milsom
England
Great to interact with you and your response is really appreciated …
i have failed many times and returned radios to China often - but the chase & reprogramming transceivers floats my boat - and keeps an old man happy. I enclose a picture of my collection; all reprogrammed via a CPS or via CHIRP …
doriboni
The D models are GMSK digital, I think it's the same software for the whole range: BF-W31D, BF-T20D, BF-888D...
Have you tried this software?
h_milsom
England
The CPS that works is "BF_Series CPS" but the *TRICK* is that it will NOT work with an FTDI cable!
Use a standard Baofeng K-type.
Phew ...
jhiggy
It seems weird that the radio won't program with an FTDI cable. I have the same issue and just ordered an CH340 cable and will let you know if that fixes mine as well.
The reason that this is odd- they are both serial cables but they use different serial chips. But-- serial is serial regardless of which chip is emulating it. I always buy FTDI when given the chance because the drivers on CH340 are difficult most of the time--and typically- FTDI is a much better chip for reading and writing serial. (This is coming from my fire alarm panel experience)
Curious what you all think might be causing this if changing to a different chip really does fix this issue?
Phew ...
jhiggy
Well no idea why this worked but the CH340 serial cable works and I was able to retrieve the channel list from the radio. In case others need it here it is:
BF-V12D​
CHRXFreqTXFreqRxCTCDCSCodeTXCTCDCSCodeTxPowerBandWideScanBusyLockJumpCodeIntercomeModeEncryptionKey
1​
430.125​
430.125​
67​
67​
HIGHWIDEOFFOFFCloseImitate
2​
431.125​
431.125​
67​
67​
3​
432.125​
432.125​
67​
67​
4​
433.125​
433.125​
67​
67​
5​
434.125​
434.125​
67​
67​
6​
435.125​
435.125​
67​
67​
7​
436.125​
436.125​
67​
67​
8​
437.125​
437.125​
67​
67​
9​
438.128​
438.128​
67​
67​
10​
439.125​
439.125​
67​
67​
11​
432.725​
432.725​
HIGHWIDEOFFOFFEncryption
1​
12​
433.725​
433.725​
2​
13​
434.725​
434.725​
3​
14​
435.725​
435.725​
4​
15​
436.725​
436.725​
5​
16​
437.725​
437.725​
6​
