BIT rate Adjust XTS5000
rbluesky
I'm receiving one PD that's P25 and it's digital signal is breaking up off and on
how do i adjust the Bit rate using the tuner program? signal is better with a mobile antenna but not full quieting. transmitter is approx 6 miles away
Motorola XTS5000
Ron
N4DES
Retired 0598 Czar ÆS Ø
South FL
You didn't say what band you're listening to, but if it's 700/800 a number of licensees have contour requirements and use directional antennas so 6 miles could put you on the edge.
jeepsandradios
East of the Mississippi
Or the radio is out of tune. You need a service monitor to tune it per the manual. You can't just connect it to tuner and turn values and hope. There is a process.
n3obl
ØAES-1056
PA
thats the problem. These radios are over 10-15 years old as a minimum and people just buy them off ebay and get a cheapy cable and copy of software and all of the sudden they are a radio tech-nishun! Any used radio should at a minimum be bench tested with a full alignment on a service monitor.
