BK KNG-2 won't boot when powered up
footage
Pacific Rim
My KNG2-P150 suddenly won't boot up when powered up. I've tried it with two freshly charged batteries. Is there a reboot sequence or a local fix to this, or do I need to send it in for service? This is an almost new radio. Thanks.
rsmith7799
Arroyo Grande, CA
Good morning, do you have the software and programming cable? If you do, hook up the radio to your computer, get the radio into bluelight special mode and load up the newest software that is available (5.5.0 r) If you need some more info you can call me and I'll go through it with you.
footage
Pacific Rim
I do, but the radio won't turn on and therefore I don't think it's really connecting to the computer. Or does it not need to be turned on?
footage
Pacific Rim
I should be clearer. The radio doesn't power up with a fresh battery. I tried to connect it to the computer but that didn't affect the state of the radio. Have you seen this before?
IAmSixNine
Dallas, TX
When the radio last worked, was it ON and running then you noticed it was not working.
Or was it on like normal, you turned off, then at a later time you turned it on and had no response?
footage
Pacific Rim
The second case. It worked fine in the evening, wouldn't power up in the morning. Charged up two new batteries, neither worked. I keep thinking this is something really simple that I'm not seeing clearly.
rsmith7799
Arroyo Grande, CA
Get the radio hooked up to your computer and get the radio into blue light mode. It seams it’s not on but it actually is. The BLUELIGHT will light up, get Lightning Light up and hit the START button.
footage
Pacific Rim
I do see that 5.5.0s is a fix for this problem. I've installed Lightning Light and fixed the driver permission issue but I can't get radio and computer to talk to each other. Probably my inexperience with Windows.
Thanks anyway.
IAmSixNine
Dallas, TX
Yikes, glad i got mine updated to 5.5.0s
hope BK takes care of its customers if the 5.5.0r firmware had a bug in it and caused the radios to not turn on anymore.
rsmith7799
Arroyo Grande, CA
So to add misery to this dilemma, I was told that there is a ribbon cable that is failing on the KNG2CMD series. I have sent a few back to the Depot and to a repair facility AFTER the warranties had expired.
