Jeremy is the man. See you in a few weeks in Huntsville......Depending what you want the radio to do, it might cost close to $6000
I used Jeremy at the below address. Great guy..
Cross-Connections
35860 Pauba Rd, Temecula, CA 92592
951-764-4022 cell
jeremy@cross-connections.net
www.cross-connections.net
This may not apply to OP. If they're buying a single unit, then they are likely a hobbyist.You have to find a dealer in your state. If there is not one, you will have to go direct through BK (who may approve the use of an out of state dealer). The dealer agreement for the BKR9000 and upcoming BKR9500 has a geographic restriction to the state the dealer is based out of. This was done in part to keep several of the big dealers from cutting all of the local competition out. In comparison, the agreement for the BKR5000 and KNG M-series essentially restricts to no less than nationwide or global operations.
You'd have to read the dealer agreement. It doesn't allow for a single unit sales case exception though. The way it's written the exception would have to come from BK.This may not apply to OP. If they're buying a single unit, then they are likely a hobbyist.
EFJ is more flexible than BK on some of their dealer agreements.I would look at 49er communications. They are pretty easy to deal with and do work with single customers. I was able to get a quote from them on a VP8000 with little trouble. I didn't end up buying from them because I found a more economical price, but the service was there.
Was told I could get a full loaded XL-200 new from his dealer for $1800. Which seems like a pretty good price. I need to dig more into programming these and the good and bad things about them
Does the state have a quantity purchase agreement with EFJ and other vendors like we do?I'm getting ready to buy more, and will be going with the EFJ.
DHS: Approved Radio List
www.in.gov
Jest got 6 VP8000s, other than them being a little on the fat size I like them much better than the APX8000 that i have been using for 10 years IMHO.
And we have a mix of P25/Analog/DMR and the VP8000 handles all of that with ease
I've heard one reason for wider head design is the LTE and now maybe D2D satellite antennas need space at the top. This will be interesting to see.Thinner head design, single line top display. Designed for people that are not wearing structural fire gloves when they use their radios.
I wonder what the ratio is for PD v FD portable quantities per jurisdiction. FD seems to be the marketing target, don't think I've ever seen a portable advertised asMeantime, most of us do not need 'glove friendly' radios.
