End 2011 I wrote a post describing how cambria county should apply and obtain a grant for the full upgrading of their new analog system to p25 FDMA Conventional. Seeing as it has the perfect amount of tower sifes and already obtained FCC Frequency assignments. With a little imitative and a grant written based on a lack of interoperable communications with Blair and Washington township along with a emense amount focused on safety. This aspect is important due to the ammount of dead areas(not spots... AREAS) hindering and sometimes flat out blocking the ability to communicate. Cambria should create a commission to seek upgrading the system for FREE!
As fof blair, I love your system but it only took me 3 seconds usong my xts2500 with FCC and federal flashcode BY ACCIDENT NOT ON PURPOSE to affiliate to the system and clone your dispatch ID. The radio does this as a feature and was overlooked after programming your system using FPP. I recomend an IP connect update with shiftable keys and radio isolation features. Upgrading to IP Connect will give you the DPH modem in your vehicle to attach an MDT to use for high mbps data transfer.
Or just upgrade to des or aes encryption.
BLAIR P25 was MY IDEA FIRST. I can forward the forum post suggesting it to you if needed.
P25 conventional is easy to hack and using some features very very easy to trick or disorient system users wjth ghosting, cloned radio id's especially if the hackers radio has its emergency activation feature ENABLED
I live far away and don't mess with your system But come on ...3 seconds by accident. Lol
