Bluetooth help
johnny517
Hello is it possible to buy a bluetooth transmiter/reciever plug it in to head phone jack on gre 500 and play it threw car stereo i currently use a aux cable and want to see if this is possible and do away with the cable.thank you for any help
johnny517
hello does this need to be a reciever or transmiter to work threw car im hearing diffrent thoughts which mode wil actually work recieve or transmit thanks
dave3825
Suffolk County NY
If you want to listen to your scanner that does not have bluetooth, on a car stereo that does, you need a bluetooth transmitter,
johnny517
hello i just got my c28bluetooth transmitter/reciever and im getting nothing.i thought i put device in transmit mode plug it into gre -500 scanner and when i do it cuts sound out i hear nothing threw car stereo can someone give some suggestions as to what im doing wrong. thank you for youre help. maybe im just hooking it up wrong????? i plug tbluetooth device in the head phone jack of gre-500 and it cuts sound out of scanner but i hear nothing threww car stereo what an i missing i put device in transmitter mode
wtp
Port Charlotte FL
you would have to pair it with the receiver/bar radio.
you will probably have to read the radio manual.
dave3825
Suffolk County NY
When you plug anything into a headphone jack, it will route the audio to what’s plugged in, and will disrupt the audio going to the speaker. So in other words, that is normal.
I am sure some directions came with the C28 which is a transmitter and a receiver. Make sure the c28 is set up as transmitter and not receiver. Then put it into discovery mode and have your stereo search and pair with it.
johnny517
dave thanks again but what do you mean by discovery mode
dave3825
Suffolk County NY
Discovery mode is a state within Bluetooth technology integrated devices that enables Bluetooth devices to search, connect and transfer data with each other. Discoverable mode is used to propagate the availability of a Bluetooth device and to establish a connection with another device.
So another words your C 28 needs to put out a signal and say hey I’m here, you can connect to me. Your stereo will see the open connection and connect.
johnny517
ok i tried connecting with bluetooth and it only shows my phone i guess im just not getting it directions that came with it not real good
dave3825
Suffolk County NY
It shows on your phone because most phones automatically go into search mode when you go into the Bluetooth settings. You need to consult with the manual for the stereo in your car as that would explain in detail how to get your car stereo to search for Bluetooth device.
fxdscon
¯\_(ツ)_/¯
Do you know for certain that your car stereo has Bluetooth capabilities built in... if not, do you have a Bluetooth receiver connected to it?
Have you successfully used any other Bluetooth device through your car stereo?
dave3825
Suffolk County NY
What is the year make and model of the car and is the original factory stereo?
dave3825
Suffolk County NY
I think you can get to bluetooth by pressing the Audio tab, and or setup, then bluetooth.
